  SoarerCentral * Air Conditioning and Climate Control * EMV strange problem? Previous Previous    Next Next
Radoslav Galev
Bulgaria
Reg: 12-2019
Sunday, December 29, 2019 - 06:03 pm, by:  Radoslav Galev (Galev_90) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hello guys.My name is Radoslav.I am from Bulgaria.I bought a soarer v8 1991 before a month.The car is very low mileage, around 77.She is with emv.Something very strange happen.When i click vent button, the screen go black, and can't control climate control. All other button, when i click it shows options on Japanese, but most important vent control so not work.I opened the emv 2 times, all connections where i think that can be bad, are resoldered by me.Fuses are okay.
Have you got any idea, how i can fix this thing.. some transistor, or faulty capacitor or other?.I search, and do not find exactly the same problem..
I really do not like the emv, and would like a standard control from tt model, but yesterday i checked the orange connectors under the dash left side of the steering column/wheel, and they look without enough length for work...Any idea or help what to do are really helpful.Thank you guys
Goetz von Gneisenau
UZZ31 V8
Reg: 03-2019
Monday, December 30, 2019 - 11:35 pm, by:  Goetz von Gneisenau (Sunshine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sounds like the EMV computer needs a rebuild. Make contact with the Soarer Surgeon (Mike Beck) in New Zealand who is good at refurbishing these units. I would keep the EMV working rather than convert, but your choice.
Tom Richards
Tuesday, December 31, 2019 - 09:15 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
there are a lot of thin pcb tracks going back to the plug. If you have the skills look for corrosion on them. Measure the resistance from the plug to the other end of the track. If you find a open cct solder a thin wire from the plug to the other end. I had this problem 12yrs ago and that was the fix. Sorry i cannot remember any more detail. Also look for any electro cap that is leaking or bulging out at the end. replace it if leaking.
3UZ-FE V8 4.3 UZZ32
Wednesday, January 01, 2020 - 09:42 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Seems Radoslav found me on my Soarer Surgeon page.
Found me on Ebay first though haha.
Thanks for the recommendation Goetz.
The direct cause of the above problem is the computer being faulty. But that also means the rest of the units common problems are due to occur soon as it's unlikely they have been fixed before, and counter productive to only fix one of the few core faults these units get.
