  SoarerCentral * Air Conditioning and Climate Control * Turn A/C off and I can hear a cap-gun sound Previous Previous    Next Next
Mark Donovan
n/a
Soarer V8 Limited
Monday, March 27, 2006 - 06:57 pm, by:  Mark Donovan (Mark_donovan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The noise started after picking the car up from it's last service (3 weeks ago). When the A/C is turned off (OFF button), I can hear what sounds like someone firing a cap gun. The sound is not as distinctive when I am standing outside the car, but it's there and it's annoying.
Lexus think it's a big job that will require removing the ducting etc., but I reckon it could be something easy to find. I can see that the compressor in the engine bay is making the usual noises and is not responsible. What else could it be?
thanks
Mike Mortimer
Thursday, April 27, 2006 - 09:35 pm, by:  Mike Mortimer (Mikemort) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I know that when the same thing happened to my soarer it was the compressor that needed replacing...
Good luck with it.
