  SoarerCentral * Mechanical - TT * General Mechanical * Looking for a mechanic around parramatta Previous Previous    Next Next
Pravind Chand
tt
Reg: 01-2007
Sunday, May 11, 2008 - 10:26 am, by:  Pravind Chand (Pcsoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hi...does anyone know a good mechanic around parramatta that could fix my soarer problems. have lost power and idals rough. changed the spark plugs but still no luck. found little bit of oil in one of the plugs. so if anyone could help out with this will be appreciated. thanks.
George Funa
Reg: 05-2006
Sunday, May 11, 2008 - 11:12 pm, by:  George Funa (Fun001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pravind
Take your car to Nial at 2 Hale st Botany 96666364.
I know it is a bit out of your way, but, he can fix your problem.If you have any major problems, it is well worth the trip out there. Once it is fixed then you can take it to the local mechanic to do minor things like change oil and or brakes
