  SoarerCentral * Mechanical - TT * Injection & Fuel Systems * Very loud ticking from injectors/fuel rail. Previous Previous    Next Next
Matchy Loi
GTT
Tuesday, August 04, 2009 - 05:45 pm, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I noticed a loud ticking coming from the injectors/fuel rail, I've put a screw driver on it and listened and it's definitely it.
I know injectors are meant to tick but not this loud.
I've also compared it to a friends Soarer, and mine is much louder. It's loud enough that you can hear it over the engine.
Does it indicate that something is wrong?
Matchy Loi
GTT
Thursday, August 06, 2009 - 03:37 pm, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Does anyone have any input?
Walter Gillmore
TT JZZ30
Reg: 07-2009
Thursday, August 06, 2009 - 06:06 pm, by:  Walter Gillmore (Cl33pa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
have the injectors been changed over by a previous owner or yourself?
Shane Van Ross
Reg: 11-2008
Thursday, August 06, 2009 - 08:13 pm, by:  Shane Van Ross (Shane_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matchy...dunno what the noise is mate...im sure it is common with all soarers tho...im not sure what exactly causes te ticking noise....when we compared cars though...mine was definitely more quiet than yours...but i could still hear the tick...hope some guru comes to our rescue
Shane Van Ross
Reg: 11-2008
Thursday, August 06, 2009 - 08:21 pm, by:  Shane Van Ross (Shane_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
After some research...opinions relate to the "solonoids....in the injectors"...quite normal...some tick more than others...i would like it to go away tho...
Also...what happens when you overtighten the fanbelt...is there a squealing noise associated with that...
Scott Wilkes
Tasmania
92 TT Factory Manual
Reg: 10-2008
Thursday, August 06, 2009 - 08:51 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
you cant really over tighten the fanbelt mate as its got a automatic tensioner, its not a manual adjuster
Matchy Loi
GTT
Friday, August 07, 2009 - 11:56 am, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I haven't changed them, but I can't say if the previous owner did or did not, nor do I have any way of contacting them.
Walter Gillmore
TT JZZ30
Reg: 07-2009
Friday, August 07, 2009 - 01:00 pm, by:  Walter Gillmore (Cl33pa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
could possibly be different injectors. different ohms than what the toyota uses?? research more into the what ohms your injectors should be. then get a multimeter and you can test your injectors ohms with one. ( i think its resistance your measuring so be sure to select the correct setting on the multimeter!)
Christian Molenda
T
Friday, August 21, 2009 - 01:20 pm, by:  Christian Molenda (Christof) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Fot a TT, they should be yellow top injectors standard. If thats what they are then no probs.. And as mentioned, they can be loud. This doesnt mean anything
