  SoarerCentral * Mechanical - V8 * Where to Get Cheapest Spark Plugs Previous Previous    Next Next
Sam Rex
Reg: 01-2008
Wednesday, December 17, 2008 - 02:52 pm, by:  Sam Rex (Samrex) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Local Peps want $19 each can someone help me out or let me know where to get these at a reasonable cheap price..
Has anyone tried the NGK BKR6ES-11 the standard NGK ??? Any good??
Thanks in advance
Robert Pressnell
Reg: 11-2008
Wednesday, December 17, 2008 - 06:11 pm, by:  Robert Pressnell (Bob_pressnell) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I got aset of Denso plugs from Toyota i got aset of X8 for $88 but i get trade price.Try afew different Toyota Dealerships and you should find a Toyota place that'll have them for about $13.00 each.The prices differ from each Toyota dealer from $13 TO $16.50 i've found.That here in Melb anyway
Denso:-)K20R11
Denso:K16TR11 (You can also go with these plugs they are cheaper than the PK20R11.But they wont last as long as they are'nt Platnium.From what i've been told and found myself you are better going with a good set from day1.
Brett Harrison
Wednesday, December 17, 2008 - 08:59 pm, by:  Brett Harrison (Bretto) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sam, just use BKR6E-11's there fine, and there around $ 2.50 to $ 4.00 a plug. They work just fine, you don't need platinums.
Friday, December 19, 2008 - 06:22 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
For the amount of time and effort involved in replacing the V8 plugs, definitely go with platinums or even better iridiums. Coppers will only last about 20,000k's, and just don't spark as cleanly as an iridium, which will last 60,000 or even 100,000kms. Unless you enjoy pulling all those covers off of course.
$19 isn't a terrible price for iridiums - but keep a look out for sales coming up after xmas and you'll save a bit I bet.
Tom Richards
Friday, December 19, 2008 - 08:22 am, by:  Tom Richards (Tomr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ask ralph bull @
http://www.forparts.com/index.asp
delivery is a couple of days
good prices for everything, rotors, disti caps, leads. he knows the car and can supply a good "kit" to do a major service.
Soarer Limited UZZ31 V8
Friday, December 19, 2008 - 05:28 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I get 8 NGK Iridium plugs delivered for $120 NZD from a guy on TM.
Quite good value in my opinion.
Gary Nimmo
V8 Supercharged & intercooled
Friday, December 19, 2008 - 11:07 pm, by:  Gary Nimmo (Gazzasore) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
WWW.SPARKPLUGS.COM
Very Cheap all sorts of things on here
Mine cost about $8 delivered
