  SoarerCentral * Test Post and Forum Issues * Door trim problems Previous Previous    Next Next
Georgia Main
Reg: 10-2006
Tuesday, October 10, 2006 - 08:53 pm, by:  Georgia Main (Georgiamain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a '91 Soarer. The drivers side door trim has had to be removed because it is broken - it seems to be in two pieces. The under-layer seems to be in good condition but the 'attachment' (where your elbow would rest)is broken )one section is snapped through) and I don't think it can be repaired. Any idea of how I can get this fixed without having to get a whole new door trim which has been quoted at $1500? Is there somewhere I can get a second-hand door trim??
Lawrence Ostle
tt
Reg: 12-2005
Wednesday, October 11, 2006 - 06:41 am, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Have you tried a motor trimmers? Generally they are able to weld the plastic, recover, reinforce etc. A local trimmer did my window trim, and although not EXACTLY the same, is quite acceptable for a 14 year old car.....
Adam Lonergan
UZZ32
Wednesday, October 11, 2006 - 06:59 am, by:  Adam Lonergan (Alchemistal) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Why bother when new ones can be ordered from Toyota for $250.
Lawrence Ostle
tt
Reg: 12-2005
Wednesday, October 11, 2006 - 10:50 am, by:  Lawrence Ostle (Lawrence) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Georgia notes in her post she has been quoted $1500.....
For $250 you would buy new certainly.
Georgia Main
Reg: 10-2006
Wednesday, October 11, 2006 - 02:56 pm, by:  Georgia Main (Georgiamain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks everyone - I was quoted $1500 for a new door trim from this website - James Sloane at Toyota in NSW.
If I could get a new trim for $250 I will just do that - any ideas where to go?
Wednesday, October 11, 2006 - 03:37 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Georgia,
Firstly to SC, and secondly, if you'd like to tell us your chassis number, I will be able to give you the EXACT part number to price/order through Toyota.
Tref Abbott
queensland
soarer 2.5 TT
Reg: 10-2006
Thursday, October 12, 2006 - 10:13 am, by:  Tref Abbott (Tref) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
And now....the cheap way (in case you're interested)
I had the same problem a couple of years ago. Being stoney broke back then (erm...no change there then) I took the interior panelling off and fixed the broken areas myself. This will sound ugly but I used fibreglass cloth. Two years later and it's still working perfectly.
I actually found about three breaks in the plastic panel so it took me a few hours to fix 'em all. My interior trim is lightish grey and I managed to find something very close to that colour in the loacl Spotlight store (you know, the store the wimmin disappear into when looking for dress fabric and when you go in after 'em an hour later you realise what hell is really like).
I had looked at getting the EXACT material from an auto upholsterer but it would have cost an arm and a leg.
I just copied the positioning of the old trim and although the whole process took a couple of days I was delighted with the result. Quite honestly you can't tell that it's any different to original.
Ben Lipman
Thursday, October 12, 2006 - 07:41 pm, by:  Ben Lipman (Ben12a) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I did a temporary bodgy job also. $250 is still a lot of money too me.
I was lucky in that the trim had not torn yet, but you could see it starting to stretch.
I used a LOT of Araldite and some metal strap from a stereo mount to brace the crack and replace some of the screw tabs. After 6 months still going strong.
Georgia Main
Reg: 10-2006
Saturday, October 14, 2006 - 02:51 pm, by:  Georgia Main (Georgiamain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks everyone - Don - the VIN number is: 6T91MPV97Y2FMA008
(Hope that's the right number you need- let me know if not)
Sunday, October 15, 2006 - 08:41 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Georgia,
No, that's the VIN number.
What I need is the chassis number from the original Toyota data plate under the bonnet, as in JZZ30******** or UZZ30******* or UZZ31*******, depending on whether your's is a TT, 4.0-GT, or a 4.0-Ltd.
And also the TRIM code from the data plate
Georgia Main
Reg: 10-2006
Tuesday, October 17, 2006 - 02:42 pm, by:  Georgia Main (Georgiamain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Don - ok, think I've got it this time
It's JZZ30-0016149
Trim code - FB10
Colour - SJ5
Hope that's right!
