  SoarerCentral * Test Post and Forum Issues * Photo upload test Previous Previous    Next Next
Nick Ebbrell
wirral
soarer V8 gt limited
Reg: 11-2006
Friday, November 10, 2006 - 05:09 am, by:  Nick Ebbrell (2fast2real) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
well here goes nothing, why do they make those photo resize programmes so darn fiddlywill take some better snaps if this works.nick.
Friday, November 10, 2006 - 06:12 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nice wheels!
94 UZZ31 (V8) / 96 JZZ30 (TT)
Friday, November 10, 2006 - 02:27 pm, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nick, open your pictures in Microsoft Paint. Press Ctrl + W. The Stretch and Skew box will appear. Enter different percentages in the 'Stretch' boxes to get different sizes, until you get your desired size. To make sure the picture adheres to SoarerCentral's size limit, press Ctrl + E to view the image's attributes. DO NOT change any values in this box as this will cut out edges of your pictures.
Since you've resized the images in MSPaint, you should have no problems with the image size limit since MSPaint tends to lower the image quality when edited through MSPaint. This is not visible to the naked eye though.
This is a simple way to resize photo's mate, no need to install third party software.
Bog Standard Active
Saturday, November 11, 2006 - 10:45 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
There is a program I use called resize.exe. You can find it with google, Or I'll find it again soon and put up a link. so simple, you give it a max dimension and it does all the rest for you.
Drew Hebblethwaite
Alberta
1JZ-GTE Twin Turbo
Reg: 01-2007
Friday, January 05, 2007 - 01:24 pm, by:  Drew Hebblethwaite (Canadiancole) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://img.photobucket.com/albums/v171/LorienTiger/My%20Car/product_u2-1-20831-80.jpg
[IMG]http://img.photobucket.com/albums/v171/LorienTiger/My%20Car/product_u2-1-20831-80.jpg[/IMG]
Rob Andreacchio
Supercharged VT Calais & 1991 JZZ30
Reg: 01-2005
Friday, January 05, 2007 - 01:28 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hmmmm...
http://soarercentral.com/cgi-bin/sc-forum/discus.cgi?pg=formatting#images
Friday, January 05, 2007 - 01:31 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Drew..........nice looking Soarer you got there!
Cameron Schembri
JZZ30 2.5 GTT
Monday, January 29, 2007 - 09:21 pm, by:  Cameron Schembri (Camosoarus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Justin Hughes
2.5 GT-T JZZ-30 212rwkw @ 15 psi
Monday, January 29, 2007 - 10:12 pm, by:  Justin Hughes (Juzza) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nupp - can't see shoite - try again.
Ken Cornell
UZZ30 Soarer
Reg: 01-2006
Wednesday, January 31, 2007 - 09:27 am, by:  Ken Cornell (Dunadan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That car looks sweeeet! Nice ride Cameron.
