  SoarerCentral * Test Post and Forum Issues * Speedo noise???? Previous Previous    Next Next
Charles Leeson
soarer GT twin turbo
Friday, March 30, 2007 - 02:17 pm, by:  Charles Leeson (Jay) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i have a retro 87 soarer and i leave for work around 5am, and when im leaving the driveway and start heading down the road my speedo starts making some sort of scratching noise and it speeds up as i go faster, but it only does it for a couple of mins and while im goin under 35kmph, but it wont make a sound when the temp warms up a bit. the sound isnt loud but i know its there it sounds like a mouse trying to get out or somethin' WTF is this sound?????
Alan Carter
Friday, March 30, 2007 - 02:38 pm, by:  Alan Carter (Alky) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Step 1: Stop
Step 2: Remove mouse from speedo
Step 3: Drive on.
Sorry Charles, I don't know the answer - someone with more than half a brain will be along anytime soon...
Friday, March 30, 2007 - 04:29 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Charles,
Contact rodents-r-us.com and they will will remove the vermin from your speedo
Other than that, like Alan, I can be of no assistance.
Steve Latimer
UZZ32
Friday, March 30, 2007 - 05:35 pm, by:  Steve Latimer (Latsus) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Charles,
definately temperature related...once temperature increases enough the cats on your car will start working and hence the mouse scratching noises will stop (as they don't wish to get caught)
Hahahaha
refer to posts above for more info
Friday, March 30, 2007 - 11:20 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
At a guess, it uses a mechanical speedo and the gears and stuff are making the noise, or possible the wire turning in the cable.
If it's an electronic speedo however, then refer to the posts above.
Saturday, March 31, 2007 - 07:01 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have had a similar issue with a speedo cable - the inner cable was dry. I pulled it out, poured oil down it and problem was solved.
Charles Leeson
Saturday, March 31, 2007 - 11:20 am, by:  Charles Leeson (Jay) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok thanx anyway. its an electronic speedo no cables at all. i will just look around for another instrument cluster.
Andrew Ferres
'86 Cressida V8, '84 Soarer V8, '90 C-F Celsior V8
Sunday, April 01, 2007 - 11:22 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It may be an electronic readout, but it could well be cable driven.
I know the early JZX81's are electronic readout, and cable driven, but the late JZX81's are electronic driven as well.
I've just never been sure about the early Z20 Soarers.
Andrew Meiers
Sunday, April 01, 2007 - 02:29 pm, by:  Andrew Meiers (Acmtt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The Z20 is a driven cog with a speed sensor on it at the gearbox. 4 pulse i think.
