  SoarerCentral * Test Post and Forum Issues * Please help,slow cooking to death Previous Previous    Next Next
Wess McManus
v8
Tuesday, October 16, 2007 - 04:01 pm, by:  Wess McManus (Bar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Can someone please advise,
After being burdened with stuffed aircon windows fail. Right window always slow to wind up,now all i get is dull click and no movement.Left window which was previously fine now very slow and sticks. I assumed regulator on its way out but now left window stuffed simultaneously!
I read on another thread elec.power delivered in parallel.power supply problem?
Is there a trustworthy electrician/mechanic sydney area? any advice appreciated.thanks
Tuesday, October 16, 2007 - 04:56 pm, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
90% of the time lubricating the window rubbers will solve slow moving window problems - treat all the rubbers with silicon or other suitable rubber lubricant. If the windows stopped moving all together its most likely too late though.
Wess McManus
v8
Tuesday, October 16, 2007 - 06:10 pm, by:  Wess McManus (Bar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
G Day Matthew,
Thanks for reply,
I sprayed some silicon spray on outer rubber tracks last week and I felt it improved the speed of windows,but now at a loss to understand why left window weak...It was particularly hot today could it be possible however unlikely slows
windowrails Ill have to open up door on my day off. CHEERS MATE
Dave Rose
wa
uzz31
Tuesday, October 16, 2007 - 09:05 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wess did the silicon run down the window channel its got to get right down to the bottom.
and have the engine running while you work them that way you will have the full 13.8 volts across the motors...good luck...DR
Wednesday, October 17, 2007 - 05:17 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I did have success on my wife's Levin by removing the door trims and lubricating the runners with lithium grease, but the Soarers have always just needed a spray every year or so.
Dave Billings
Louisiana
SC 300, Manual Transmission
Reg: 06-2007
Wednesday, October 17, 2007 - 05:49 am, by:  Dave Billings (Waveman1717) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Slow cooking to death..hmmmmm, on an open fire, rotissary, or in a pan? lol
Wednesday, October 17, 2007 - 11:07 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wess, may I ask what this has to do with either Test Posting or Forum related issues?
Brian Kelly
Colorado USA
Reg: 04-2007
Wednesday, October 17, 2007 - 11:40 am, by:  Brian Kelly (Whereswaldo583) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
he is obviously testing his ability to piss off the moderators.
Dave Rose
wa
uzz31
Thursday, October 18, 2007 - 09:58 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
??????..DR
