  SoarerCentral * Test Post and Forum Issues * Best upgrade for a twin turbo jzz30, need advice Previous Previous    Next Next
David Wojcik
Soarer(TT)
Reg: 08-2008
Friday, August 15, 2008 - 06:20 am, by:  David Wojcik (94tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i want more power and more response.
also i have a fmic thats 600x300x100 and hks pod and boost controller with 12-13psi at the moment. I have a budget of 3 thousand. I have a trust exhaust cat back system waiting to be put on. havnt put it on because i don't wont more show then go. can anyone help please!
XTR T-66 Turbo
Friday, August 15, 2008 - 01:43 pm, by:  James Harris (Haro) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi David,
Welcome to the club mate, your post is in the wrong section but im sure Peter will sort it out for you !
As for your question.
I personally would be ditching the HKS filter as they are not the best and slapping in another brand POD or better yet even putting back in the original airbox and making a BFI (do a search for BFI). BUT if your intercooler pipes do not allow for the airbox to be put back in - make sure the pod is getting some good clean air by using some ducting.
Also a good idea to perhaps head to clark rubber and buy some heat resistant rubber (with the silvery backing) and make up a small basic cold air BOX for your pod to sit in so its not sucking hot engine air.
The cat back will make a difference and increase show at the same time. A good idea would be when you get that installed get an exhaust shop to make up a nice 3" Front pipe from the stocko dump pipes and get a high flow cat also.
That will make a substantial power difference. Then perhaps a simple SAFC II install and a tune. Or an Emanage... whatever floats your boat.
Should see you up to 200RWKW with a little more boost.
Prob cost about half your budget also
David Wojcik
Soarer(TT)
Reg: 08-2008
Saturday, August 16, 2008 - 06:25 am, by:  David Wojcik (94tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for your help mate!
hey just wanna ask another thing.
If i combine your advice with a stallie and quick shift kit, could i run a low 13's in the quarter mile?
What stallie should i get when i get one?
i was looking at a 2000rpm one or should i get a
2500rpm one?
I've already ran a 14.75 with stock boost.
(not the 12-13psi that i'm running now)
Just one more question (LOL)
If i put Nos in tha car will it blow my engine up quickly?
