  SoarerCentral * Test Post and Forum Issues * Test Only - Hi Peter! Previous Previous    Next Next
Malcolm Hall
UZZ31 V8 Ltd
Friday, December 12, 2008 - 12:56 pm, by:  Malcolm Hall (Neddy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi Peter - if you see this then please ignore my request for a new login - it's so long since I had posted as "Neddy" that I had forgotten my password - doh... If this gets posted all is well - thanks.
Friday, December 12, 2008 - 03:01 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No probs, I just deleted the new account.
Joshua Rao
JZZ30 vvti GT-L, 94 TT manual (being wrecked), Legnum VR4
Reg: 09-2006
Wednesday, March 25, 2009 - 05:09 am, by:  Joshua Rao (Soaren1) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
bold italics again
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Wednesday, September 16, 2009 - 12:41 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
using thread to figure out how to submit non-locally hosted pictures...
<img><br><br><a href="http://img604.imageshack.us/content.php?page=blogpost&files=img10/5258/090915164945.jpg"><img></a> Quickpost this image to Myspace, Digg, Facebook, and others!
<img>
<img> </img>
\img {http://img10.imageshack.us/img10/5258/090915164945.jpg}
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Wednesday, September 16, 2009 - 03:19 pm, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah i can't figure this out.. i end up just somehow linking images via html..
so many photobucket links, maybe i should try with that more..
<img>
Wednesday, September 16, 2009 - 04:27 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Best is to upload the image direct into your post, that way it's not dependant on an external server.
Next best is to copy the image address, eg.
and then click the Thumb icon above the "Add Your Message Here" box and paste in the copied address, so it works like this:
Aiden Cheese
Soarer jzz30
Reg: 09-2009
Friday, September 18, 2009 - 11:20 am, by:  Aiden Cheese (Chillpen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
"Best is to upload the image direct into your post, that way it's not dependant on an external server. "
The workaround at work only really works with a specific site which doesn't use conventional ports to upload..
The second solution is basically what i was looking for, I assumed it had to be somewhere, or some code somewhere.. turns out it was \imagepair which i wouldn't have ever guessed :-)
David Grab
T78
Reg: 01-2008
Thursday, October 15, 2009 - 08:34 pm, by:  David Grab (Blastedbyasoarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Friday, October 16, 2009 - 06:05 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Oh dear, what's the story behind that one?
Carl Mccormack
'91 Soarer TT
Reg: 09-2010
Sunday, July 10, 2011 - 09:15 pm, by:  Carl Mccormack (Eville) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
