  SoarerCentral * Test Post and Forum Issues * ECL Power switch on shift console Previous Previous    Next Next
Ken Brahniuk
British Columbia
2.5 twin turbo
Reg: 12-2008
Tuesday, January 27, 2009 - 12:36 am, by:  Ken Brahniuk (Ken_b) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am new to my Soarer, what is the purpose of the ECL power switch ? Should you run with it on during normal driving ?
Tuesday, January 27, 2009 - 06:44 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Depends on what model Soarer you have and what options it came with as to exactly what it does. Use the "Search" function to see what others have said about it in the past. At a minimum on all models it will allow you to lock the transmission into 2nd gear from a standing start (so starting in 2nd it will really start in 2nd), apart from that it will also transmission behaviour on downshift/upshift/kickdown (holding gears to higher RPM) and if you have TEMS it can firm up the ride.
Rob Andreacchio
I've sprouted horns!
Reg: 01-2005
Tuesday, January 27, 2009 - 01:11 pm, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
search will be hard....because there is no ECL switch.... its ECT
