  SoarerCentral * Test Post and Forum Issues * V8 alternator Perth Previous Previous    Next Next
Anthony Wah Day
W.A
Soarer GT V8
Tuesday, February 10, 2009 - 08:08 am, by:  Anthony Wah Day (Naastee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all, alternator died in my 1992 v8, took to local auto electrician has come back in bits in a box, they can't fix. Bit pisssed off with them. Can anyone recommend place to buy another in Perth
Chris Lock
sa
Reg: 03-2008
Tuesday, February 10, 2009 - 09:58 am, by:  Chris Lock (Sledge) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Did they charge you anything?
If so, take it back and tell em to put it back together.
If not, then yeah, take it elsewhere..
Soarer Limited UZZ31 V8
Tuesday, February 10, 2009 - 07:41 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What a hopeless shop, they should be out of business!
As Chris asked, did they charge you anything? I certainly hope not!
Anthony Wah Day
W.A
Soarer GT V8
Tuesday, February 10, 2009 - 10:46 pm, by:  Anthony Wah Day (Naastee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No they didn't charge for the bits they gave back, we have put back together just to get a idea of physical size(obvious bits not returned in the guts of the alternator).Another mob said they can get us a new unit for $350 so have ordered, it comes with a oval plug hopefully I can get/make a adaptor cable to my round plug ( as per an earlier thread)so with a bit of luck should be back on the road in a day or so
Wednesday, February 11, 2009 - 06:11 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Make sure your power steering pump isn't leaking or it'll just happen all over again.
Anthony Wah Day
W.A
Soarer GT V8
Wednesday, February 11, 2009 - 11:19 pm, by:  Anthony Wah Day (Naastee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks its all in and working, power steering pump is dry as a bone, alternator just died naturally, have been trying to make a cover for alternator just in case.Purchased from Odin Auto Parts Balcatta Ph 0893453224 Alternator ANJ012, Oval/Rnd adaptor cable E38-2008 $350.00 all up
Sean Tonkin
Soarer V8
Reg: 01-2009
Friday, February 13, 2009 - 05:02 am, by:  Sean Tonkin (Shorn) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Anthony, good to hear you got your car mobile again. Mine's still in the workshop, waiting for the mechanic to try and work out what's up.
Found some good sources of after-market parts in perth after about 100 phone calls. Let me know if you ever need any help with that.
