  SoarerCentral * Test Post and Forum Issues * Forum upgrade needed! Previous Previous    Next Next
Camron Garcia
Kingston
Reg: 10-2007
Tuesday, May 12, 2009 - 08:31 am, by:  Camron Garcia (Killacam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am finding this forum very troublesome to use in comparison to others I have joined. I would love to see some upgrades since I find Soarer Central to be the most informative Soarer forum. Simple stuff like a link to unread replies to our posts would make it much more user friendly. Threads should open on the first page and the other page numbers displayed so we can select it. I think this forum is kinda ancient and a new look would be welcome :-)
Dave Rose
wa
uzz31 v8
Tuesday, May 12, 2009 - 12:43 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Troublesome...??...I think its informative because of its format , easy to use.
Tuesday, May 12, 2009 - 02:36 pm, by:  Callum Finch (Sigeneat) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I concur with Dave. In my experience of the various forum and BBS packages available Soarer Central is certainly one of the better systems.
It may not have the same "cutting edge" tech in it as most Web 2.0 setups however what we have here is quite appropriate for the content in my opinion.
If you are looking for new/unread posts then you can click the "New Posts" button in the top left of the menu at the top of every page.
V8 Ltd manual
Tuesday, May 12, 2009 - 03:34 pm, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
New Posts lists threads with unread topics and posts since you last clicked it, and clicking on the first post in such a topic takes you straight to it, give or take the fact that it does not cope well with pictures.
You also have to consider that Oz Soarer forums do not charge any money for access to all of their facilities, so if you are asking the Admin (Pen) to switch to new software, I hope you can dream up a persuasive reason why he should take time out from making a living to incur that extra cost and effort.
That last sentence was not a flame, just explaining things.
Tuesday, May 12, 2009 - 04:45 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Simple answer is that promised software upgrades have never materialised so we are pretty much stuck with the way it works now short of heavy custom work.
Is it actually works quite well now though, especially if you explore it's features rather than just want it to look like what you are used to.
So, if an upgrade became available, it would be implemented.
Evan Kaio
Beautiful sunny good @ rugby Wellington
'91 UZZ31
Reg: 01-2007
Tuesday, May 12, 2009 - 06:39 pm, by:  Evan Kaio (Knave) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I find this type of Forum easy to use.
Some of the other forums that use different formats have too much happening on one page
and can be confusing (for me).
David Vaughan wrote on Tuesday, May 12, 2009 - 03:34 pm:
Yes very true Xeno.
Wednesday, May 13, 2009 - 05:58 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its fast and easy on the eye, don't change it.
Jordon Codd
W.A
01 WRX
Reg: 08-2006
Wednesday, May 13, 2009 - 10:55 am, by:  Jordon Codd (Soarermad) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I reckon this forum is great how it works all i reckon it needs is a few different pics and some maybe new colouring in the backgrounds and stuff then it would be sweet.
David Grima
1JZ-GTE TT
Reg: 07-2007
Thursday, May 14, 2009 - 07:51 pm, by:  David Grima (Maltezr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think the site works fine the way it is also, but I think it would be good in the PARTS/CARS FOR SALE sections to separate the STATES just like it is in the EVENTS section in which the parts or cars are located so everyone can look for parts locally first before looking in another state. The way it is at the moment I find it a little time consuming clicking through the parts section for example only to find that they are in different states. IMO it would be easier and quicker to look for items if you separate them. The way it is now you have no idea where the things listed for sale are until you click on them.
Dave Hart
Waikato
UZZ32
Friday, May 15, 2009 - 07:22 am, by:  Dave Hart (Davyboy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've been on a few sites and this is by far the best.
Keep it up Pen.
Friday, May 15, 2009 - 10:36 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks for your appreciation Dave.
Camron Garcia
Kingston
Reg: 10-2007
Friday, May 15, 2009 - 01:13 pm, by:  Camron Garcia (Killacam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Didn't know that other forums charged. In that case, this one is pretty brilliant for free :-)
SLK 230 Kompressor
Saturday, May 16, 2009 - 11:46 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It ain't broke............so why fix it!
Peter has done a sterling job of what started some years ago as an online hobby because of his enthusiasm for the Soarer (and related cars).
I KNOW that he spent many, many hours modifying and tweaking the basic package to the point that it is today............Believe me, it ain't no off the shelf plug n' play package.
And he did all that while juggling the needs of family and his ACTUAL income earning job.
I totally agree with Dave Hart and others, that this is by far the simplest/easiest site to navigate.............and it's FREE!
This is NOT having a go at folks who've posted about possible forum changes, rather it is providing a bit of background to SC, and how it came into being.
Bloody well done Peter.............Keep it up!
David Goldthorpe
UZZ31 GT-L
Reg: 11-2007
Saturday, May 16, 2009 - 10:49 pm, by:  David Goldthorpe (Sprocket82) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm yet to see a car enthusiast support forum as informative, user-friendly, comprehensive and well laid-out as this one. It's a pity too, because, when the time comes to buy my next car, I'd like to have the same sort of online support that I've had here.
540i E34 V8
Saturday, May 16, 2009 - 11:17 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Exactly, this forum is nice and simple, it loads, doesnt have all the lagy graphics other ones have. Plus its unique!
Leave it as is Mr Nitschke. :-)
Don Bagnall wrote on Saturday, May 16, 2009 - 11:46 am:
Haha! I learnt that when I pulled the heads off the old UZZ31 to replace the valve seals! Waste of time - though educational!
Doug Jardine
'97 UZZ31 V8 4.0 GTL
Sunday, May 17, 2009 - 01:58 pm, by:  Doug Jardine (Drj) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey Cameron - constructive ideas always welcome I'm sure.
A timely reminder to thank Peter and all contributors from day one for their ongoing efforts.
One of the main reasons I was comfortable buying a Soarer is because of the community of support through this site.
Works for me - agree - "It ain't broke............so why fix it"!
