  SoarerCentral * Test Post and Forum Issues * This website, stuck in the past ? Previous Previous    Next Next
Open in new windowArchive through February 21, 2010Mike Beck25
Michael Fabian
JZZ31 2JZ
Reg: 07-2008
Sunday, February 21, 2010 - 07:16 pm, by:  Michael Fabian (Mf_sc300) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How many times is this subject going to be raised?
Blake Gloyn
manawatu
soarer JZZ30 TT
Monday, February 22, 2010 - 10:04 am, by:  Blake Gloyn (Blakenz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
MY FAVOURITE FORUM!!!!!!
Camron Garcia
Kingston
Reg: 10-2007
Monday, February 22, 2010 - 11:38 am, by:  Camron Garcia (Killacam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My issues:
1) Where do you go to see your "Private Messages"?
2) How can I see new replies to posts I have made?
3) I don't mind the countless topics on one child board as it makes it easier to search for keywords... But way too many posts are displayed when the "New Posts" button is pressed - It takes eons to load. Please limit it to 20 per page.
4) Why is it when a topic is over one page long, you can't see the numbered links so you can simply click them? It would be of much help to display page links within the topic so we can select each page.
Christian Somerville
UZZ31 V8 LTD
Reg: 03-2009
Monday, February 22, 2010 - 12:00 pm, by:  Christian Somerville (Csomers) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cameron, private messages goes to your email inbox you put down when you singed up.
Camron Garcia
Kingston
Reg: 10-2007
Monday, February 22, 2010 - 12:27 pm, by:  Camron Garcia (Killacam) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thank you Mr. Somerville!
Now, rather than "Archive through February 21, 2010" being at the top this page, I would prefer to see "Page 1 2" displayed at the bottom of every page in the topic so we can select it.
Monday, February 22, 2010 - 12:46 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Use the "New Posts" button more often to reduce the number of posts listed. :-)
Changing the "Archive" at top of page to "Page number" at bottom of the page is non-trivial.
This forum has over 600 edits away from the standard package as is, which has been quite a challenge since I am not a programmer.
When I created SC and did all the customisation, it was a pretty full on and time consuming experience. I will probably get back into it at some point, but right now the weather is too nice outside and I am enjoying other things in my life as well as my Soarers, so sitting at a PC for endless hours isn't a winning proposition.
Tuesday, February 23, 2010 - 06:34 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wow, I live in NZ with the crappy 7.5MBps that passes for "ADSL2" here, and NOTHING on this forum takes ages to load... what are people using? Dial up?
Evan Kaio
Beautiful sunny good @ rugby 'Canes'
'91 UZZ31. 92 TT
Reg: 01-2007
Tuesday, February 23, 2010 - 04:41 pm, by:  Evan Kaio (Knave) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew Sharpe wrote on Tuesday, February 23, 2010 - 06:34 am:
Yeah. What he said.
Maclean Cherry
Celsior
Reg: 01-2010
Tuesday, March 02, 2010 - 09:19 pm, by:  Maclean Cherry (Maclean_cherry) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just saw this and thought I'd throw my 2c in.
I'm relatively new but do have a fair bit of experience running forums and get to use most of the available software through my job.
New Posts: People are saying it works well? It runs off a cookie stored on your computer. Awesome except if you access the site from more than one computer. That means if I log on from my laptop and then from my PC the same threads are still new.
ToolTips: If you want to make the forum easier to use, include tooltips on the functions. Things like inserting a link or editing a post aren't obvious without clicking on each button and waiting to see what it does.
Avatars and signatures: Any new forum software will give you the option to disable these.
If you want to keep it free, check out PHPBB as already mentioned. You may not already have MySQL databases available, you can get hosting that comes with it for about $3/month. If you can't find suitable hosting send me an email and I'll host the site for you $5/month on one of my VPS's.
Could go on but these are just a few things.
Wednesday, March 03, 2010 - 12:21 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
New posts works on when you last checked, so you won't get it all again on a different PC.
Did you actually test this?
Tooltips are included in the site, if people choose not to use them, not much I can do.
Avatars and signatures are already disabled here.
We already use MySQL.
Wednesday, March 03, 2010 - 06:12 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You need to put IE8 into compatibility mode for tool tips to function. I suspect its a daft IE8 issue more than anything to do with the forum.
I use this forum regularly from 3 different PC's and my iPhone, and "New" always returns only the messages since I last clicked on it. Works perfectly every time.
Maclean Cherry
Celsior
Reg: 01-2010
Wednesday, March 03, 2010 - 09:17 am, by:  Maclean Cherry (Maclean_cherry) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter Nitschke wrote on Wednesday, March 03, 2010 - 12:21 am:
New Posts: Sorry, I didn't mean the new posts screen. I ment the new posts image and bolded thread hyperlinks when threads are new.
Tooltips: Yes I have tested it. I tested IE8 (not using compatibility mode) FireFox 3.6, Opera 10.10 and Chrome 4 and they didn't come up. - Matt: This would point to a forum software issue lol
Avatars: I know, I was commenting on a post above about a reason for not going to newer software was that it gets clogged out with avatars and signatures etc. I personally like it without huge sig blocks, but I like avatars because it makes it easier to put faces (cars) to names. Horses for courses though...
MySQL: Ok cool, makes upgrading easy ;) I had assumed this was an old version of YaBB which uses flat file txt db's.
I'm not trying to slag you off, my post in the other thread was probably (ok, definitely) a bit emotional. The forum just really is outdated and really doesn't help with new member retention.
Anthony Matthews
Soarer GT Limited V8
Wednesday, March 03, 2010 - 09:28 am, by:  Anthony Matthews (Gajet) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think at this point, I'd like to say thank you to Peter (and Don) for providing such a GREAT forum for FREE without MOUNTAINS OF ADS.
And more importantly, for reducing the amount of SMS speak I have to put up with daily.
325i Coupe
Wednesday, March 03, 2010 - 01:12 pm, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was using a 'better' modern website today and I found it so slow and difficult to use.
Makes me appreciate this much simpler forum. :-)
Keep it up Mr Nitschke!
Wednesday, March 03, 2010 - 02:24 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
SLK 230 Kompressor
Wednesday, March 03, 2010 - 03:06 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Anthony Matthews wrote on Wednesday, March 03, 2010 - 09:28 am:
Ta muchly
