  SoarerCentral * Test Post and Forum Issues * Admin possible for a new section Previous Previous    Next Next
Richard Luong
SC400 V8
Reg: 03-2010
Monday, June 28, 2010 - 12:21 pm, by:  Richard Luong (Reggiebangbang) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys just seeing if we get enough info together we could make a table or reference area for part numbers aprox pricing and compatible parts. And throw in local wreakers and contact details?
I've found that most of the times Toyota/lexus and auto shops don't stock our parts but have manage to use parts from a lexus gs, land cruiser etc. Might be helpful to others.
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Monday, June 28, 2010 - 03:32 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Good Idea, been a while since we had a useful thread here. Only thing is you cannot edit your original post after 720 Hours, so maybe an Admin can enable you to keep on editing that post to add more info into the table.
So Richard you can add columns such as :
Part, Shop/Location, Cost, Shipping (if from USA for example), Total Price, Link to website or contact number, Notes (to add important info) etc.
Not sure how you're going to have the table formatted but keen to see how you go about it.
Let's begin the table.
I'll start.
1jz-gte Seals (JZZ30)
Castle Hill Toyota :
Valve Cover Gasket 11213-88400 - $32.31 each
Camshaft Seal 90311-38041 - $14.58 each
Front Engine Oil Seal - $25.26
Rear Engine Oil Seal - $72.85.
1jz Timing Belt From :
Auto One and Repco (dayco/Bosch) - $50.
1jz-gte/2jz-gte (Interchangable) Water pump :
GMB Brand - CNS Auto Parts (USA) - $53 USD + 39 USD Post
Toyota Genuine - $140 AUD.
Richard Luong
SC400 V8
Reg: 03-2010
Monday, June 28, 2010 - 03:55 pm, by:  Richard Luong (Reggiebangbang) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What I can try and do I make it into a data base on exel and submit it to the admin people it'll take a while so what I hope to do is speak to someone who works in Toyota parts.
If anyone has a good friend/mate works in toyota parts I'm sure they could put a data base of parts on to a USB.
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Monday, June 28, 2010 - 04:15 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
1jz-gte Seals - Driftmotion (USA)
Front Seal - $15 USD
Rear Seal - $38 USD
Cam Seal - $9.99 USD
Valve Cover Gasket set - $21 USD (Both Gaskets)
Monday, June 28, 2010 - 06:38 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Too hard.
Aaron Casey
Monday, June 28, 2010 - 06:47 pm, by:  Aaron Casey (Blownminiturbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
would need constant update but if you are after parts go to
www.toyodiy.com you can find any part for it there then quote the number to a toyota dealer.
David Henderson
Nsw
Reg: 08-2007
Monday, June 28, 2010 - 09:31 pm, by:  David Henderson (Hendo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah I usually use toyodiy.com or toymods
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Tuesday, June 29, 2010 - 02:50 am, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah but point of this is to get a list of different sources for parts, I take it you guys wouldn't be keen quoting the part number for a new climate control unit.... $3000.
Well Richard you could just use a free web host and make a table on there and just link to it.
E36 Coupe
Tuesday, June 29, 2010 - 07:33 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I don't see the need
It's something you can easily search for.
Boris Siljanoski
Soarer GZ20 TT
Reg: 11-2007
Tuesday, June 29, 2010 - 06:29 pm, by:  Boris Siljanoski (Z2tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Makes it easier to have all the info in one table.
Richard Luong
SC400 V8
Reg: 03-2010
Tuesday, June 29, 2010 - 08:23 pm, by:  Richard Luong (Reggiebangbang) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sweet I'll start geting some of the info down from that website. Make like a PDF parts guide or an online reference.
I'm sure this will be useful to all of us at some stage seeing parts are getting harder to source so hopefully with this we're able to help each other out with parts that are similar.
