  SoarerCentral * Test Post and Forum Issues * Profile. * Archive through February 01, 2009 Previous Previous    Next Next
Rod Quaife
Waikato
Sunday, September 24, 2006 - 07:27 pm, by:  Rod Quaife (Rod_quaife) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
How do I put a photo of my car on my profile.
Ben Lipman
Sunday, September 24, 2006 - 07:33 pm, by:  Ben Lipman (Ben12a) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
From memory...Click on profile and then edit profile (you will need to enter username and password). From there click on picture and follow the prompts. Upload picture or something like that.
Sunday, September 24, 2006 - 07:33 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Start by clicking the Profile button at top of the screen. Scroll down until you find the option to add your photo. :-)
Sunday, September 24, 2006 - 07:40 pm, by:  Don Bagnall (Baggs) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah Rod, wot ^^^ said
Rod Quaife
Waikato
Tuesday, September 26, 2006 - 04:28 pm, by:  Rod Quaife (Rod_quaife) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Peter, but where is the profile button at the top of the screen. Maybe I have missed something but us old guys and computers dont get on very well sometimes. Spent about 30 minutes clicking on everything but no joy.????????
V8 Ltd manual
Tuesday, September 26, 2006 - 04:39 pm, by:  David Vaughan (Davidv) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rod, scroll this screen right to the top so you can see the Soarer Central name and picture. There you will see two rows of words with the second word, after "Posts" being "Profile". Click on it and follow through on the screens that come up. Then, see what Peter said.
Alan Carter
Tuesday, September 26, 2006 - 05:50 pm, by:  Alan Carter (Alky) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Of course this only works if you're actually logged in.
Tuesday, September 26, 2006 - 05:51 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
So does posting to ask the question in the first place :-)
Rod Quaife
Waikato
Wednesday, September 27, 2006 - 06:14 pm, by:  Rod Quaife (Rod_quaife) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Sorry David but Posts and Profile dont appear on my screen under Soarer Central name and picture. Just the usual name, password log in and register thingys, and under that search tree view etc but no "profile" Back to those who know about these mysteries.
Wednesday, September 27, 2006 - 06:17 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rod, the Name and Password stuff should be replaced with Profile and other options if you are logged on.
V8 Ltd manual
Wednesday, September 27, 2006 - 06:29 pm, by:  David Vaughan (Davidv) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
which is the condition in which you post, as Pen said earlier.
Wednesday, September 27, 2006 - 07:03 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just tested it. If you are logged out, there is NO profile option. You can still post by putting username/password in next to the post, but once you have posted you are then logged in.
So Rod, maybe make sure you are logged in before you look for Profile.
The other big advantage of being logged in, is the New Posts button.
Thursday, September 28, 2006 - 06:47 am, by:  Matthew Sharpe (Madmatt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Could be a browser config issue?
V8 Ltd manual
Thursday, September 28, 2006 - 07:59 am, by:  David Vaughan (Davidv) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cookies, but he may deliberately have set up to reject them
Thursday, September 28, 2006 - 10:39 am, by:  Matthew Sharpe (Madmatt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mmm, cookies...
Rod Quaife
Waikato
Thursday, September 28, 2006 - 05:45 pm, by:  Rod Quaife (Rod_quaife) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well now I have consulted a mere female on this problem and she suggests that when logged in the screen changes with the profile bit coming up, it doesnt for me so if I was logging in with a slightly different password it would tell me wouldnt it ? When I do posting I use same log in name and password but still cant get the profile bit at top of page.
Thursday, September 28, 2006 - 05:51 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rod, what happens if you log in at the top?
Rod Quaife
Waikato
Thursday, September 28, 2006 - 06:45 pm, by:  Rod Quaife (Rod_quaife) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Nothing at all Pete just flicks back on same screen.
Friday, September 29, 2006 - 03:32 am, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aha! Found the problem (I think). You must have edited your profile once before and turned off "Remember my username and password in a cookie".
I have turned it back on for you, see if it helps. :-)
If not, then you are also blocking cookies in your web browser. :-(
Friday, September 29, 2006 - 04:23 pm, by:  Don Bagnall (Baggs) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rod!..............you cookie blocker you!.
Tsk!, Tsk!.
Rod Quaife
Waikato
Friday, September 29, 2006 - 05:35 pm, by:  Rod Quaife (Rod_quaife) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I plead not guilty probably my son who comes down periodically to fix problems, in fact the other one does as well, both got computer science degrees so what they dont know about these is not worth knowing but cant get hold of one of them cause he is in London on a course for the firm he works for. Anyway Pete you have fixed the problem as all signs have come up now. I wouldnt know a cookie blocker if I fell over one. Ta for the perserverance.
Friday, September 29, 2006 - 05:36 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No problems. Happy to have a win for you! :-)
Brendan Harsh
Soarer GT-T VVT-i Manual
Reg: 02-2007
Sunday, February 01, 2009 - 02:01 pm, by:  Brendan Harsh (Smoov_jz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hey guys I know that this is a really old post but I have the exact same problem.
It's driving me insane, I have been trying over and over to change cookie and every other internet setting even tried on a mates computer.. but still can't get the profile button, as I have changed email addresses twice I can't even change to the new address.
Can someone help me, please...
bsplace84@bigpond.com
Sunday, February 01, 2009 - 03:22 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Brendan, I changed the settings for you, see if that helps.
Brendan Harsh
Reg: 02-2007
Sunday, February 01, 2009 - 09:17 pm, by:  Brendan Harsh (Smoov_jz) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Whoa thank you so much peter .
This makes Soarer Central so much easier to use.
