  SoarerCentral * Test Post and Forum Issues * What doesn't work... Previous Previous    Next Next
Jason Hall
SC400 Ltd V8
Reg: 02-2010
Thursday, September 09, 2010 - 12:29 pm, by:  Jason Hall (Halljps) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Testing if my profile has died...
Jim Burrough
UZZ31 x 2, UZZ32
Reg: 08-2006
Thursday, October 06, 2011 - 02:45 pm, by:  Jim Burrough (Jfb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Peter,
Different issue. Noticed in last few days that there are no yellow flags displaying on unread posts. Is that a forum matter or a personal problem, please?
Thanks Jim
Jim Burrough
UZZ31 x 2, UZZ32
Reg: 08-2006
Thursday, October 06, 2011 - 05:54 pm, by:  Jim Burrough (Jfb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well, maybe solved my own problem....possibly had an open-ended post alive and living somehow even when the computer was switched off. The log-in details below the drafting box were already filled in (not inserted today) when I typed and sent the above post. The 'Test Post and Forum Issues' thread then showed a yellow flag (as now have posts from other contributors in other threads).....problem solved!.... but not sure why ???
Monday, October 10, 2011 - 07:58 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Was the "new posts" button still working?
Jim Burrough
UZZ31 x 2, UZZ32
Reg: 08-2006
Monday, October 10, 2011 - 07:55 pm, by:  Jim Burrough (Jfb) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Matthew,
Not sure - didn't think to try. Do not recall even the New Posts having a yellow flag, although it is probably a permanent feature. Anyway, all is working fine now.
