  SoarerCentral * Test Post and Forum Issues * Mystery engine issue Previous Previous    Next Next
Daniel Bonnor
soarer uuz31
Reg: 06-2014
Saturday, October 28, 2017 - 06:55 pm, by:  Daniel Bonnor (Majorlunacy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi all first post and i have a head scratcher. I went to use my v8 soarer started up fine backed out to the street, and only got a few hundred meters away and it died got it back home. It cranks over but doesn't want to start i've good spark from both coils and all the leads and plugged a injector test light in and get a good pulse from it. Ect/ecu pin test was ok tried the b+fp bypass pump runs but still no start. Went through all the fuses, i even pulled the fuel return to check for flow and seemed ok but i'm at a total loss as to where the problem is and any help would be nice
Scott Vim
Soarer (1uz) Chaser (1jz)
Reg: 12-2010
Tuesday, October 31, 2017 - 08:27 am, by:  Scott Vim (1uz1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Spray some start ya bastard into the airbox and see if it starts.
Dave Rose
Tuesday, October 31, 2017 - 12:37 pm, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
crank angle sensor??
