  SoarerCentral * Test Post and Forum Issues * Soarer UZZ31 Airbag light with error code 41 Previous Previous    Next Next
Goetz von Gneisenau
UZZ31 V8
Reg: 03-2019
Thursday, October 24, 2019 - 03:29 pm, by:  Goetz von Gneisenau (Sunshine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have a 1991 Soarer UZZ31 with Airbag light on.
When following Harry Lemmens procedure, the SRS light comes straight back on after the reset procedure. The error code 41 that I am getting isn't listed when shorting Tc and E1. Any ideas?
Goetz von Gneisenau
UZZ31 V8
Reg: 03-2019
Thursday, January 16, 2020 - 01:00 am, by:  Goetz von Gneisenau (Sunshine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
All fixed now. The airbag ECU had leaky caps, which I had replaced but airbag light remained with error code 41 still on.
I found I was moving the earth wire to slowly between the two pins, had to toggle the earth wire as fast as I could, then cleared the airbag light fine.
Dave Rose
Thursday, January 16, 2020 - 09:37 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Its a great reference site Goetz , hope its always here when we need it. shame facebook spoilt it. i did join for a while but its just kids swearing .
Goetz von Gneisenau
UZZ31 V8
Reg: 03-2019
Thursday, January 16, 2020 - 10:57 am, by:  Goetz von Gneisenau (Sunshine) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yes I agree, I added the fix because unfortunately there are too many fault trails with no feedback for the final fix. I bought a spare airbag ecu, but it had same leaky caps, restored it as well.
Good to have a spare. I really like this site for so much help in keeping these cars running.
