  SoarerCentral * Test Post and Forum Issues * One side lower Previous Previous    Next Next
Stewart Hale
Staffordshire
Reg: 08-2021
Monday, August 16, 2021 - 03:19 am, by:  Stewart Hale (Hts888) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
OK,Newbie and have searched forum, tried some of the recommendations without success. So, I fitted new wheels the other day and did not switch off the air suspension in the boot, now, the driver side is higher, is it a sensor issue? it did not happen on passenger side and I did both the same, Help me please guys, Thanks Stew
Damien Nikiforides
uzz32 (#805, #556)
Reg: 08-2011
Monday, August 16, 2021 - 09:26 am, by:  Damien Nikiforides (D_nikiforides) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Take the battery off for a bit, then re-connect.
Go for a drive see if it levels out.
If it doesn't its possible you've damaged a rod/bent something on the senor to make it think its level when its not.
Dave Rose
Tuesday, August 17, 2021 - 08:53 am, by:  Dave Rose (Sand_groper) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
its ok not to switch off suspension as long as you did not turn on ignition. as Damien said go for a drive first.
