  SoarerCentral * Test Post and Forum Issues * Forum windows popping into focus driving me crazy!!! * Archive through April 20, 2006 Previous Previous    Next Next
Paul Irwin
GT-T (1JZ-GTE)
Wednesday, April 19, 2006 - 08:09 am, by:  Paul Irwin (Rival) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
SoarerCentral.
Each time i go to open a new window in SoarerCentral.com and then scroll down the new messages to open another one the window that i was previously opening always waits till right before i click the next message and JUMPS in focus.
this is driving me nuts. i use a tabbed browser at home so its ok, but here at work i used IE and the windows popping into focus after loading is driving me berko!
Cheers,
Luke Nieuwhof
Wednesday, April 19, 2006 - 08:32 am, by:  Luke Nieuwhof (Luke_nieuwhof) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think I know what you're talking about where it jumps to the front of whatever you're doing. It's very annoying when you leave it to load and go back to do something else then it interrupts? Is there something that can be done to change it?
Will Adams
Soarer GT-TL
Wednesday, April 19, 2006 - 08:45 am, by:  Will Adams (Draco) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah it drives me nuts too. At work I am using IE, but at home I am using Firefox and obviously using Tabs for different windows.
Shouldn't this be in Forum Issues though?
Wednesday, April 19, 2006 - 08:55 am, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think this got mentioned right after SC was launched. Don't recall whether anyone was able to put their finger on the cause. Since then, it has been forgotten about.
Unless any web coders have some suggestions, probably the only way to track it would be to set up a dummy forum then slowly add in the modifications until the problem was duplicated.
Seeing as it doesn't happen to me, that would be a very laborious task :-\
Can we perhaps have a count of how many people it is affecting, that can't deal with it eg by adding a tabbed interface such as Crazy Browser?
Wednesday, April 19, 2006 - 08:56 am, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://www.crazybrowser.com/ if you are interested - very nice front end for browsing.
Rob Andreacchio
UZZ31 V8 / JZZ30 TT
Reg: 01-2005
Wednesday, April 19, 2006 - 09:10 am, by:  Rob Andreacchio (Reepa) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pete.. I honestly think everything is being caused by 1 thing... the water applet...
If removed I would think it will stop the page focus in IE6, the underlining text in firefox & IE7, and the mammoth resource hogging..
Worth giving it a try?
UZZ32 ( V8 )
Wednesday, April 19, 2006 - 09:10 am, by:  Perry Morgan (Uzz32) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I was the one pissing and moaning about it when it was launched as I was using ie at work. I like to go through the forum and open all the windows I want to look at and then read em but ie brings each one to the front as they open. Like Paul said, it drives ya mental. I fixed it by using firefox everywhere now lol.
Wednesday, April 19, 2006 - 09:36 am, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aww.. No water applet? Geee...
Will look into it later - probably today.
Will Adams
Soarer GT-TL
Wednesday, April 19, 2006 - 09:48 am, by:  Will Adams (Draco) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I like the water applet, and every now and then just attack it with the mouse just to see well the water swirl around. Maybe a picture like a Soarer up there with the Eye Candy still going on down the bottom.
Matthew Tai
Wednesday, April 19, 2006 - 01:36 pm, by:  Matthew Tai (Matttai) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeh the water applet is a resource hog. Not on my home pc but at uni the computer just dies. Java is becoming more and more bloated. The worse thing is if your browsing different webpages that both use different applets it will open up two instances of itself!!! die!!!
Luke Nieuwhof
Wednesday, April 19, 2006 - 02:02 pm, by:  Luke Nieuwhof (Luke_nieuwhof) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Aha here is the missing thread!
Actually replacing the water applet with Soarers is not a bad idea. What if members could submit photos of their cars at the correct size to be randomly put up?
Paul Irwin
GT-T (1JZ-GTE)
Wednesday, April 19, 2006 - 02:24 pm, by:  Paul Irwin (Rival) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
keep the water thing, have it in a stress relief section.
sorry about putting this in the wrong section i realised after i posted it and came back to check and realised it should have been in this area.
thanks for moving it.
Adam Lonergan
UZZ32
Wednesday, April 19, 2006 - 02:32 pm, by:  Adam Lonergan (Alchemistal) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
www.maxthon.com <- good for work as it overlays IE and gives you tabbed windows. All your favourites, proxy setting etc work OK even when you're on a different machine with only IE installed.
Simon Triantafillou
Soarer Turbo
Rating:
Votes: 1 (Vote!)
Wednesday, April 19, 2006 - 04:14 pm, by:  Simon Triantafillou (Soarer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maxthon for the win... tabbed browsing, without the hassles of moving away from IE.
Rating:
Votes: 1 (Vote!)
Wednesday, April 19, 2006 - 05:12 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maxthon sounds similar to Crazy Browser then.
OK, first up there is a minor upgrade to Discus that has just been released, though I don't think it will affect this issue at all. I will apply it tonight.
Next, there is a 2nd upgrade, pretty much out of beta that I will probably wait a little longer before applying. No new user features are in these 2 minor releases.
I will also disable the water applet and we can test if that makes any difference.
The difficulty that I have, is that the IE pop-up problem doesn't happen here, possibly because I am on an ethernet link to the server so the pages come up too fast. So testing is difficult.
Change of colour scheme isn't going to happen, I like it just as it is. Anyone that doesn't can put a coloured filter on their screen. :-)
Changing the basic layout isn't going to happen either. Making changes isn't trivial, and there can be flow-on effects that impact on other parts of the screen. If you want variety, turn your monitor on it's side.
Jeff Smith
TT Limited :-)
Wednesday, April 19, 2006 - 05:47 pm, by:  Jeff Smith (Mozzie) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
like you simon I use maxithon to good browser easy to use.the tabs are great.
Wednesday, April 19, 2006 - 06:25 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I may start on doing a backup and applying the first upgrade soon, so if you see "Maintenance Mode" then that is what is happening, but it should only last for a few minutes at a time.
Simon Triantafillou
Soarer Turbo
Wednesday, April 19, 2006 - 07:28 pm, by:  Simon Triantafillou (Soarer) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pen, perhaps test a program called NetLimiter... you can set connections (per application) to be limited to any speed you like, even over ethernet.
Wednesday, April 19, 2006 - 07:37 pm, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Probably simpler to set up a dialup connection and see if I can get it to happen.
Richard Baird
Perth, WA
Toyota Echo
Wednesday, April 19, 2006 - 09:58 pm, by:  Richard Baird (Richo) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am running IE7 Beta 2 no problems...
Woohoo tabbed browsing with explorer....!!
3.0 GT
Thursday, April 20, 2006 - 06:16 am, by:  Matthew Sharpe (Madmatt) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I never have any problems here either due to high speed (2 megabit dedicated internet + fast computer) - but I did a test and it does the same thing.
Yeah, don't change the colours or layout, its easy to read and looks "mature" unlike most car forums.
Thursday, April 20, 2006 - 07:42 am, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Matthew, a lot of work went into the design and layout of SC, and readability, ease of use, and soothing colours were all part of what I was trying to achieve. :-)
Thursday, April 20, 2006 - 08:01 am, by:  Peter Nitschke (Pen) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
About to tackle the upgrade now, so expect to see maintenance mode for a short while.
Thursday, April 20, 2006 - 08:55 am, by:  Benny Gammelmark (Oldfield) Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't change the layout Peter. Just remove the applet.
Mine does the same thing but it's really not a problem. I think we should think of people that have problems with it though.
I like the idea of a eye-candy style thing that puts in peoples cars instead but I don't know how much work this would involve.
