  SoarerCentral * Test Post and Forum Issues * Suspension stuck on high Previous Previous    Next Next
Peter Callingham
Thursday, June 29, 2006 - 07:43 pm, by:  Peter Callingham (Pwc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Gday All,
My soarer sits so high that it looks like a monster truck.
With the height set to normal and the TEMS on sport the dash still lights up with "active high".
I've only had the car a week so its been this way since I've had it.
I have read threads applicable to suspension height and will disconnect the suspension computer for a reset... any other suggestions?
Friday, June 30, 2006 - 06:19 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If you got it from a dealer, take it back and complain.
Nathan Collier
4.0 GT Limited V8
Friday, June 30, 2006 - 08:42 am, by:  Nathan Collier (Collz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i believe mine is buggered as well, ive had it since oct 04 though so i dont think i will take it back to the dealer...lol, but is there a quick and least costly way of fixing the problem?
Peter Callingham
Friday, June 30, 2006 - 09:03 am, by:  Peter Callingham (Pwc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No I bought it privately it worked the first time I test drove it. - Collz yours looks like mine - no chance of bumper scrapes with us! lol Nice wheels!}
Nathan Collier
4.0 GT Limited V8
Friday, June 30, 2006 - 09:59 am, by:  Nathan Collier (Collz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Yeah youve got that right!! lol shame it doesnt look as nice up high huh...
does your sus button work at all? or do you find the car tends to stay the same hight? if you do find out what the problem is and how to fix or have it fixed, it would be great if you could let me know. Cheers mate
Friday, June 30, 2006 - 11:04 am, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guys, I dunno whether this will assist or not, but check this link for a pdf document concerning odd 31/32 suspension faults
https://soarercentral.com/sc-forum/messages/9739/Unusual_Aibag_Faults-48292.pdf
Also, there was a run of 31's with broken suspension switch's. As in, the "Sport/Normal" mode switch appears to operate correctly, but in reality is broken internaly.
New ones are, of course available from Toyota, but most folks have repaired theirs successfully with a bit of glue & stuff.
Suggest doing a SEARCH to find the appropriate thread.
Peter Callingham
Friday, June 30, 2006 - 11:16 am, by:  Peter Callingham (Pwc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Don! Very helpful! I will attack it this weekend. Hopefully it will be as simple as a dodgy switch. I like the colour of your soarer.
Friday, June 30, 2006 - 12:29 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Peter
Nathan Collier
4.0 GT Limited V8
Friday, June 30, 2006 - 01:07 pm, by:  Nathan Collier (Collz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
{confused} thanks mate, im not sure that will help but much (dont really understand and of it...) is there a place around melb preferably close to watsonia that i would be able to take it to and have them fault find or fix it?
Friday, June 30, 2006 - 01:31 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm buggered if I know where Watsonia is??? seeing as how I'm in NEW ZEALAND, but I would suggest to ewe to clic on the Blue sponsors link directly below, and to the left of this post, as in: Sports & Luxury Cars, who are experts at Soarer problems & stuff. And yes, they are in Melbourne.........somewhere.
Nathan Collier
4.0 GT Limited V8
Friday, June 30, 2006 - 02:04 pm, by:  Nathan Collier (Collz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
LOL yeah mate sorry i forgot about the whole NEW ZEALAND thing, im still getting used to using the whole forum, thanks for you help bud.
Friday, June 30, 2006 - 03:00 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
No worries
UZZ-32 V8 Soarer #138
Sunday, July 02, 2006 - 01:35 am, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Broken switch or the wire come off the back of the switch.
Is it a '32 or a '31 with a '32 dash.
Check the diagnostics section and use search and check the alsc archives. there is tonnes and tonnes of great info here, all you have to do is find it. :-)
BTW, if it is an active, welcome to the active club, mate.
Roger Costello
UZZ31 V8 Limited
Sunday, July 02, 2006 - 11:52 pm, by:  Roger Costello (Roger) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The switch is about $500 ex Japan from Toyota so check out all the repair options first. The search function is your friend (NB we are not the search function, it is at the top of the page!) Height/TEMS switch assemblies are sometimes available from wreckers for around $50 but hard to find.
Roger
