  SoarerCentral * Z10/Z20 Soarer Chat * W58 gearbox wanted Previous Previous    Next Next
Jake Laing
queensland
gz20 soarer TT
Sunday, October 28, 2007 - 10:43 pm, by:  Jake Laing (Jake_laing) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
looking to convert my auto 1g to manual using a w58, is anyone selling a 1g manual halfcut? or manual packages? id rather find a halfcut or package than sourcing all individual parts!
Steve Morris
vic
2.0L TWIN TURBO L- GZ20
Monday, October 29, 2007 - 08:40 am, by:  Steve Morris (Purple5ive) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
try the toymods website
there was a manual conversion package for the gz20/ga70 supra/soarer in there in the classifieds section
Jake Laing
queensland
gz20 soarer TT
Thursday, November 01, 2007 - 09:14 am, by:  Jake Laing (Jake_laing) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok ive been getting quotes from shops and looking for private ads, if im gonna go to the trouble of manualising my 1g, it seems to be a better option to buy a 1j jza70 manual halfcut? im not looking for a powerhouse car but id like a comfortable 230-250rkw. From what ive been led to believe, its very costly to modify the 1g to this stage? whereas the 1j would support this power quite comfortably with a few bolt on mods?
Who has done this conversion and was it worth it? if i buy the jza70 halfcut, what other parts will i need to source?
Any help would be awesome, thanks
Steve Morris
vic
Thursday, November 01, 2007 - 09:22 am, by:  Steve Morris (Purple5ive) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Man that’s the best bet get a manual jza70 halfcut you wont need anything else
Everything you need you can get from the half cut and everything bolts straight in no modifications necessary
But to get to 250kw u will need a stand alone ecu and either a big single turbo or have to modify the stock turbos from ceramic wheels to steel wheels and hiflow them at the same time
Go to the site I mentioned before lots of people have done this conversion there
The only hard part is sourcing the halfcut which is very hard to get and the wiring
Jake Laing
queensland
gz20 soarer TT
Thursday, November 01, 2007 - 09:50 am, by:  Jake Laing (Jake_laing) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok thankss dude, i got 3 quotes from jap importer shops, all around the 4000 mark for 1j manual halfcut, all compression tested, so basically im aiming to save up 5000 at least, if i find a cheaper haflcut along the way, got more money to spend on mods . does 4000 seem reasonable? i know wiring is defintly going to be the hardest part!
Steve Morris
vic
Thursday, November 01, 2007 - 10:09 am, by:  Steve Morris (Purple5ive) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
yeah they are around that much
the worst part is trying to get them as they arent always available will be a bonus if the halfcut comes already modified with some goodies
while at it swap the brakes too as they are bigger in the jza70 ive been told
cheers
Robert Russell
soarer JZZ20 manual,MCV20 camry
Saturday, March 15, 2008 - 10:43 pm, by:  Robert Russell (Robbo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i can help with a GZ20 manual conversion kit
email me for details.
Andrew Ferres
'90 C-F Celsior V8, '84 Soarer V8, '91 Supra V8
Sunday, March 16, 2008 - 09:39 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Wanna sell me the driveshaft seperate?
I need a W58 xA70/xZ20 driveshaft (front half)
Jake Laing
queensland
gz20 soarer TT & 1jz + r154 z20 soarer :-)
Thursday, March 20, 2008 - 11:47 am, by:  Jake Laing (Jake_laing) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
im all good now guys, got a 1jz and r154 in my other z20 :-)
