  SoarerCentral * Z10/Z20 Soarer Chat * Tail shaft bearing Previous Previous    Next Next
Aaron Smith
wa
soarer mz21 7mgte single turbo
Tuesday, April 04, 2006 - 09:16 pm, by:  Aaron Smith (Aaron_mz21) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok car is at a mates been fixed due to the knocking noise and we have found the problem to be the tail shaft bearing to be stuffed they have done a few calls and have not been able to find anyone that knows these cars so does anyone here know what bearing goes in to solve the problem either toyota code or other cars that use the same bearing that i could get it out of
it's and 1986 mz21 soarer with 7mgte auto stock as a rock ( e-mz21 hcpzz) thats the model code
thanks aaron
Steve Morris
vic
2.0L TWING TURBO L- GZ20
Wednesday, April 05, 2006 - 08:22 am, by:  Steve Morris (Purple5ive) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You should be able to use a ma70 tail shaft centre bearing.
Or just pull it out and go to the shops and get them to match it.
A drive shaft specialist will definitely be able to help
