  SoarerCentral * Z10/Z20 Soarer Chat * 1jz into gz10 Previous Previous    Next Next
Tim Harris
Z10
Thursday, June 08, 2006 - 09:33 pm, by:  Tim Harris (Ae86gze) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
anyone actually done this ??
what crossmember do you use, i.e gz20 guys say mk3/A70 supra as most mechancals change over, the gz10 shares alot with mk2/A60 series supra so obviously this is different ... any experience out there ??
Andrew Ferres
Cressida V8
Friday, June 09, 2006 - 12:08 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Front sump motor
Stock GZ10 crossmember
Bonneyville automotive mounts.
Bolts in.
Tim Harris
Z10
Friday, June 09, 2006 - 04:29 pm, by:  Tim Harris (Ae86gze) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Cool thanks,
did a search on bonneyville and that brought up some gx71 coversion stuff which looks similar to z10 so cheers
