  SoarerCentral * How-to and Tutorials * How to check you idle valve to see if it ok. Previous Previous    Next Next
Michael Keen
soarer tt
Reg: 10-2007
Monday, April 28, 2008 - 02:52 pm, by:  Michael Keen (Spoilt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Candice Thomas
Reg: 05-2008
Monday, May 05, 2008 - 02:24 pm, by:  Candice Thomas (Lexusgirl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
What does all this mean? Whats an ohmmmeter? and and how do we check grounding of S1 for step 2 (a). I am new to this only 25 yr old female and just bought a soarer V8.
Brian Timms
TT Soarer Goodness.
Reg: 12-2006
Monday, May 05, 2008 - 02:29 pm, by:  Brian Timms (Turbo_brian) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ohm Meter is a basic Multi-meter you can get from Dick Smith for anywhere from $15 and upwards.
By grounding in this article, it means running a lead or probe (can get a 'test light probe from Supercheap or similar) from the S1, S2, etc pins to a grounding point int he engine bay.
Grounding point: Any bare metal area or the negative terminal of the battery.
B.
Candice Thomas
Reg: 05-2008
Friday, May 09, 2008 - 04:42 pm, by:  Candice Thomas (Lexusgirl) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
so would this mean that this would help my idle to lower! Mine is at 800rpm at the moment on idle. And would like to lower it considerably as I drive around in city a lot.
Cheers!! :-)
Monday, May 12, 2008 - 06:17 am, by:  Matthew Sharpe (Madmatt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
800 is pretty normal for the V8 as I recall.
Friday, May 16, 2008 - 03:32 pm, by:  Don Bagnall (Baggs) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
700 is the factory setting
Ashley Leach
GT Limited UZZ31 V8
Tuesday, June 03, 2008 - 02:17 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Isn't it 750? That's what my manual says...
James Barnett
Tuesday, June 10, 2008 - 09:15 am, by:  James Barnett (James85) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mine (TT) changes between 500 and 600...
Liviu Velisarie
Romania
JZZ30 GT-TL
Reg: 05-2012
Friday, December 07, 2012 - 09:37 pm, by:  Liviu Velisarie (Greenroadster) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If my TT does want to stall at idle (less than 400 rpm on cold) it means that this ISC valve is busted?
I've change a few setting on a screw on acceleration cable and now is ok - moved it further to 800RPM.
It will be a problem in the future? Should I change this valve or it is ok as it is?
Kind regards.
Chris Carr
tt
Reg: 05-2013
Sunday, May 12, 2013 - 09:02 pm, by:  Chris Carr (Sparkycarr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i would change it my tt idles at900>1000 rpm when cold and 500>600 when warm and when ac starts 900 the ISC valve controls idle for this as well :-)
