  SoarerCentral * General Soarer Chat * Dash - Change colour? Previous Previous    Next Next
Edward Salem
Reg: 01-2007
Wednesday, April 18, 2007 - 09:22 pm, by:  Edward Salem (Sydeward) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I thought itd be nice if I could change the digital speedometer from green to gold as im working on a white / gold theme for my car.
Never seen this done before though, and there isnt any info on google / here at the moment as far as i can tell..
is this possible?
Soarer VVTi
Wednesday, April 18, 2007 - 09:26 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
If the filters are available then it's possible.
Craig Webber
Wednesday, April 18, 2007 - 09:29 pm, by:  Craig Webber (Soarr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Speak to Neil he's tested a few colours.
And knows the one's that work the best.
Gold may alway's look a bit yellow.
But ha why not give it a go.
Ben Daniel
Wednesday, April 18, 2007 - 10:06 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'd be interested to know what colours Neil got.
I want a red dash but I dont think its possible ?
Ben Socratous
I am the fibreglass/kevlar/carbonfibre king!
Wednesday, April 18, 2007 - 10:10 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Red can't be done as the the lamps aren't strong enough to project clearly through red perspex (or 'filters' if you prefer). As for gold, I think the closest you will get is yellow, providing that doesn't fall into the dame category as red.
Rob Andreacchio
Supercharged VT Calais & 1991 JZZ30
Reg: 01-2005
Friday, April 20, 2007 - 10:57 am, by:  Rob Andreacchio (Reepa) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Pretty sure Red can be done Ben.. but it is not very bright... Neil does not use perspex filters.. he is special! ;)
Leon Wright
Reg: 08-2006
Friday, April 20, 2007 - 11:02 am, by:  Leon Wright (Techman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I just used filter material available at any Dj supply places. Variety of colours and heat tolerant :-)
Ben Socratous
Friday, April 20, 2007 - 05:47 pm, by:  Ben Socratous (Socrates) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Rob Andreacchio wrote on Friday, April 20, 2007 - 10:57 am:
Then I'd like to know what he gave me then!?! Either way, it looks awesome, everyone that sees it that has seen a soarer before reckons its the best thing since slice bread :-)
Active V8 and a Factory Manual XF.
Friday, April 20, 2007 - 06:25 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Not sure if red would work, as the natural light is greenish, and they have a red filter from factory to make it white.
Ben Daniel
Friday, April 20, 2007 - 07:17 pm, by:  Ben Daniel (Lexustt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Is there anyway of changing the light ??
Jeff Bedsor
Reg: 10-2006
Friday, April 20, 2007 - 07:36 pm, by:  Jeff Bedsor (Jeff_bedsor) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I am doing the dash colour change and the blinky dash fix ATM. I am having a bugger of a time trying to find the blue filters, they were available from importscene, but I just received an email saying that they no longer have them. The blue fluro is available from Jaycar, but it seems not many people use blue perspex.
Friday, April 20, 2007 - 07:52 pm, by:  Dan McColl (Hoon) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Ben Daniel wrote on Friday, April 20, 2007 - 07:17 pm:
The light across the bottom is a fluro, it can be made any colour.
The top bit, Speedo, Fuel, Temp and Tacho are special little displays, without spending huge money to have new ones custom made, I doubt you could do it.
I have a Cadillac and a Supercharged Manual V8
Friday, April 20, 2007 - 09:55 pm, by:  Neil Griffiths (Aussiesc) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Top Displays are * VFD *
Vacuum Floresant Displays
They emmit a * green * glow..
Use a colour wheel to see what you need to add to green to get your desired colour ( or close to it )
Soarer VVTi
Friday, April 20, 2007 - 11:40 pm, by:  Jose-Antonio Castillo (Ahh_soarer) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Dunno if this is possible, but would look nice (purplish-blue top section and red bottom section)... hmm....
