  SoarerCentral * General Soarer Chat * SC400 TT, Twin Intercooled, NOS etc etc Previous Previous    Next Next
Scott Casey
soarer v8
Reg: 02-2008
Thursday, June 19, 2008 - 09:26 am, by:  Scott Casey (V8soarer_1991) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
CRAZY!!!
Here is the link
http://www.supraforums.com/forum/showthread.php?t=495173
and
http://www.njtuners.com/showthread.php?p=276024
Antonio Hunt
Reg: 11-2006
Thursday, June 19, 2008 - 10:50 am, by:  Antonio Hunt (Carajo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Firetruck Me!
Chris Dmochowski
Toyota UZZ31 GTL V8
Reg: 06-2007
Thursday, June 19, 2008 - 01:05 pm, by:  Chris Dmochowski (Mr_chrisdmo) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
wow
Matchy Loi
GTT
Thursday, June 19, 2008 - 05:05 pm, by:  Matchy Loi (Ftk148) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
that is pretty wicked! I'm a sucker for all things symmetrical, i like how the highbeams feed the turbos and the short cooler piping. however, wouldn't the turbos generate lots of heat, which directly effect the effectiveness of the front mounts.
but i had to be nitpicky, so what's gonna save it from a head on collision?
Drew Rechner
Reg: 10-2007
Thursday, June 19, 2008 - 06:58 pm, by:  Drew Rechner (Drew1jz) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
SWEEEEEEEEET
Scott Gates
Thursday, June 19, 2008 - 08:24 pm, by:  Scott Gates (Scotty_001) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
WOW looks very impressive.
Jeff Bedsor
Reg: 10-2006
Friday, June 20, 2008 - 07:06 am, by:  Jeff Bedsor (Jeff_bedsor) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Might be wrong but I would think the intercoolers are going to be highly inefficient mounted at that angle, maybe a couple of big thermo's on top?
Friday, June 20, 2008 - 11:49 am, by:  Daniel Clarke (Dieseltrain) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The V mount them when using them in a Circuit style Race car setup Jeff.. Very common with drifters and circuit racers as it allows them to make longer than standard front bars and design air ducts that will flow from the bottom of the spoiler up through them. So the air is used to give alot of downpressure and will flow on through the coolers...
When mounted like this and used with speed, they will work perfectly. Remember its a race car only. ON the street is a different thing as we have to work with low speed driving and stand still.
Michael Long
Friday, June 20, 2008 - 05:11 pm, by:  Michael Long (Longy) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
sweet!! but with all that skill is it so hard to make new end tanks for the intercoolers?? but thats my only complaint
