  SoarerCentral * General Soarer Chat * Ect pwr switch excitement Previous Previous    Next Next
Open in new windowArchive through November 11, 2006Damian Ware25
Damian Ware
Saturday, November 11, 2006 - 08:16 am, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have $2 in hand waiting for more power.
Mike Bradberry
Saturday, November 11, 2006 - 11:03 am, by:  Mike Bradberry (Halflife) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'll give you $4.00 for double the power.
Damian Ware
Saturday, November 11, 2006 - 01:17 pm, by:  Damian Ware (Frozenpod) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
$4 ouch too much...
Mark Paddick
Saturday, November 11, 2006 - 01:51 pm, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Only works on UZZ32's
Saturday, November 11, 2006 - 03:30 pm, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Remove the belt?
Mark Paddick
Sunday, November 12, 2006 - 11:06 am, by:  Mark Paddick (Sparks) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Plug the cigarette lighter plug into the main acceleration sensor ($1850 ex Japan and six weeks at least to get here). It fits, the only difference is the plug colour and both are on leads the same length so will easily fit. This will instantly kill the sensor and the "active' part of the suspension. Ride height is still controlled but it squats like hell on take-off and wallows around corners....but it goes like stink.
A more professional approach would be for me to build an interceptor box for the sensor (simple, relatively cheap and I've already done it). This allow you to independantly change the amount of anti-squat or anti-dive as well as left and right body roll. Adding in a little squat increases take-off power as the suspension pump doesn't run as long (or even not at all) and general power can be increased by dialling in a little body roll which surprisingly can actually improve handling or at least add more 'feel' making it easier to drive hard. Reducing anti-dive under brakes can help turn-in to corners too.
Combined with my new (not ready for release yet!!!!!!!) Airbag/Active height controller (full replacement for the factory suspension computer which is a piece of crap and also includes a modified dash for height readout) this setup can make an Active a very interesting proposition on the track methinks.
Samuel Lantiainen
Reg: 09-2006
Sunday, November 26, 2006 - 10:12 am, by:  Samuel Lantiainen (Muli) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
so what to run the car when down the quarter? in pwr or economy mode?
Andrew Ferres
'86 Cressida V8, '84 Soarer V8, '90 C-F Celsior V8
Sunday, November 26, 2006 - 10:43 am, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Power.
It changes the shift point to just before redline.
Samuel Lantiainen
Reg: 09-2006
Sunday, November 26, 2006 - 04:21 pm, by:  Samuel Lantiainen (Muli) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
but if manually shifting from 1st to 2nd and to 3rd is it better to still have power on or no?
Andrew Ferres
Sunday, November 26, 2006 - 04:59 pm, by:  Andrew Ferres (Peewee) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
The only time you actually manually shift is when you move the shifter after the revs have past the shift change point.
So if the PWR button makes it change 200rpm before redline, it doesn't give you much room to actually manually shift.
Most of the time when you manually shift you are actually doing nothing, as the ecu still controls the shift points (unless the first scenario I said above happens)
Ashley Leach
Sunday, November 26, 2006 - 05:15 pm, by:  Ashley Leach (Ashlar) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Mark Paddick wrote on Sunday, November 12, 2006 - 11:06 am:
I look forward to it Mark!
