Blake Gloyn wrote on Wednesday, May 21, 2008 - 10:56 am:Daniel and stephen i did before and after tests with a G-tech, which has proved to be very consistent at calculating rear wheel horsepower( when accurate info is factored in.. correct weight, flat road, a number of passes,similar temp etc). So i am not making any " big claim ", just re stating the results of my soundly based tests. Please note the 25rwhp gain is with a K&N panel filter, which flows more than the standard one(not a big claim- i had them flow tested) Its not hard to believe that a standard jzz30 car produces 25 less rwhp than the same car with a well set up BFI accelerating from 50-100 km/hour on the open road. the stock factory air box is restricted,and the 'ram air effect' of a well implemented BFI really helps on a turbo car.
