  SoarerCentral * General Soarer Chat * 1jz head Previous Previous    Next Next
Justin Richardson
tasmania
Saturday, March 21, 2009 - 08:21 pm, by:  Justin Richardson (Judd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
how much power will a stock 1jz head follow???
Cameron Laufer
Soarer Central TEST'n'TUNE Saturday 25th APRIL WILLOWBANK
Reg: 12-2007
Saturday, March 21, 2009 - 08:29 pm, by:  Cameron Laufer (Ivboost) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I would say 350rwkw.
Justin Richardson
tasmania
Saturday, March 21, 2009 - 08:32 pm, by:  Justin Richardson (Judd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks cameron i was told today they would not make over 300kw what about with cams
Cameron Laufer
Reg: 12-2007
Saturday, March 21, 2009 - 09:01 pm, by:  Cameron Laufer (Ivboost) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That's with big cams mate, I class a "stock head" as being a head with untouched ports and standard size valves, also to run big cams I would upgrade valve springs.
I think a standard head and standard cams would max out at 320rwkw, but that also depends on what size turbo your running.
etuner.com.au
Sunday, March 22, 2009 - 08:14 am, by:  Cihan Aday (Cihan) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Depends how much boost you're able to run.
With upgraded camshafts & v.springs the sky is the limit really.
Justin Richardson
tasmania
Sunday, March 22, 2009 - 08:57 am, by:  Justin Richardson (Judd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks cihan yer the man dyno my car said it would not but from i get off this sit tells me it will i have t66 now to cihan and sard 800cc and the motor as only did 2500k's sins rebuild and a 3.5" exhaust all the way from the dump back and the dump is too
Jeff Bedsor
Reg: 10-2006
Monday, March 23, 2009 - 09:43 am, by:  Jeff Bedsor (Jeff_bedsor) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Justin Richardson wrote on Sunday, March 22, 2009 - 08:57 am:
Can someone translate that for me....
Justin Richardson
tasmania
Friday, March 27, 2009 - 05:41 pm, by:  Justin Richardson (Judd) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
thanks cihan yer the man who is going to dyno my car said it would not make over 300kw but from i get off this sit tells me it will i have t66 and sard 800cc inj and 272 cams with hks gears sard reg the motor as only did 2500k's sins rebuild and i have a 3.5"dump and exhaust sorry jeff must of been off my head when i tipped it lol
Gary Rollason
TT 5 speed
Reg: 05-2007
Saturday, March 28, 2009 - 10:23 am, by:  Gary Rollason (Garyr) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think maybe you still are.
Still doesn't make much sense.
