  SoarerCentral * General Soarer Chat * Emanage Previous Previous    Next Next
Nathan Hlad
soarer jzz30 tt
Reg: 09-2008
Monday, June 22, 2009 - 02:50 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
hey i am in the market for an emanage.
firstly im getting an ultimate and i want to know if i should get a f-manage and v-mangae aswell ?
not really a beast of a track car, its just my daily driver to and from work.
and also should i get a harness ??
is it really worth it ?
and whats the supplemental harness ?
is it too hard for a normal mechanic to install an e-manage without a harness ??
David Tra
qld
Reg: 11-2007
Monday, June 22, 2009 - 08:06 am, by:  David Tra (Bookie) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
This question sounds familiar. Do not bother getting vmanage.
Nathan Hlad
soarer jzz30 tt
Reg: 09-2008
Monday, June 22, 2009 - 08:31 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
is it just not worth getting v-manage or will it not go on the 1jzgte ??
this is a familiar question and has been answered before i searched and could find the thread, sorry.
i have decided to get the harness just wondering if f-manage is just for getting more feedback or is it more ?
what does the f-manage offer over just having the ultimate e-manage ??
cheers for any help and sorry for the annoying questions.
Scott Wilkes
Tasmania
92 TT Factory Manual
Reg: 10-2008
Monday, June 22, 2009 - 07:06 pm, by:  Scott Wilkes (Scottywilkes) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
V manage is really only for the VVTI from what i have gathered as it allows control of the variable valve timing etc
Nathan Hlad
soarer jzz30 tt
Reg: 09-2008
Monday, June 22, 2009 - 11:17 pm, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ok no v-manage.
and im guessing the f-manage is only for intensely tuned and modified 100k plus cars ??
so all i need is the e-manage and the harness....
no supplemental harnesses ??
cheers for any help guys
Nathan Hlad
soarer jzz30 tt
Reg: 09-2008
Sunday, June 28, 2009 - 12:25 pm, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
i am getting the e-manage ultimate and the harness but i am unsure if i need to get this supplemental harness kit....
GReddy Complete Harness Set
This is the complete harness set for the e-Manage Ultimate for new users. If you do NOT already have a Greddy e-Manage then you need this harness to work with your e-Manage Ultimate. It includes the 18-pin, 12-pin, and 14-pin connector harness.
i dont have the blue emanage do i need this harness kit if i get the emanage ultimate and the t-13 harness ??
also any thoughts on the f-manage ?
Nathan Hlad
soarer jzz30 tt
Reg: 09-2008
Sunday, June 28, 2009 - 12:45 pm, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
just a quick question....
the trust site says the emanage comes with a boost cut defencer and a speed cut defencer.
does that include a fuel cut defencer, etc.
or is that all you need just speed and boost defencers....??
what i mean is will anything be limited or cut after getting an emanage ?
Mike Dobkin
Essex
Reg: 10-2008
Sunday, June 28, 2009 - 07:31 pm, by:  Mike Dobkin (Razman) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
My emanage blue has built in fuel cut defencer (boost cut is the same thing) Do you mean speed delimiter? This is a totally separate thing afaik.
Rob Rojo
Soarer TT & UZZ31 & another UZZ31
Reg: 12-2007
Sunday, June 28, 2009 - 07:48 pm, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
When setup in the Emanage software the Emanage Ultimate removes all limiters.
Boost/fuel cut, Speed limiter and Rev limiter.
Nathan Hlad
soarer jzz30 tt
Reg: 09-2008
Sunday, June 28, 2009 - 10:12 pm, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
also do i need that supplemental harness kit or just the emanage and the t-13 harness ??
cheers.
Jeff Bedsor
Reg: 10-2006
Monday, June 29, 2009 - 08:08 am, by:  Jeff Bedsor (Jeff_bedsor) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Just the emanage and the t-13 harness
Nathan Hlad
soarer jzz30 tt
Reg: 09-2008
Monday, June 29, 2009 - 11:15 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
cool. cheers jeff.
Slav Todorovic
tt pov pack
Reg: 05-2009
Tuesday, June 30, 2009 - 11:06 am, by:  Slav Todorovic (Soar_loser) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Gday Rob, you mention that the emanage eliminates the stock ecu rev limiter is that to say that you cannot then program the emanage to what you want the rev limit to be set at??????????????
Rob Rojo
Reg: 12-2007
Tuesday, June 30, 2009 - 11:15 am, by:  Rob Rojo (Rob_tt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I should have said it can raise the rev limiter to whatever level you set it to.
Slav Todorovic
tt pov pack
Reg: 05-2009
Wednesday, July 01, 2009 - 04:26 pm, by:  Slav Todorovic (Soar_loser) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Kool thanks. When are you going to the creek again to crack that qtr mile time?
Nathan Hlad
Reg: 09-2008
Thursday, July 30, 2009 - 01:39 am, by:  Nathan Hlad (Jackpot) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Jeff Bedsor wrote on Monday, June 29, 2009 - 08:08 am:
so you dont need the -
doesn't really make sense to me....
it says i need this but is it only if i have an emanage blue ??
