  SoarerCentral * General Soarer Chat * Has anyone used or seen these turbo kits around? Previous Previous    Next Next
Matt Smith
Sc300 Non Turbo
Reg: 07-2009
Wednesday, May 04, 2011 - 08:23 pm, by:  Matt Smith (Matt_smith) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
http://cgi.ebay.com/ebaymotors/Supra-SC300-GS300-IS300-Soarer-Turbo-Kit-2JZ-GE-GTE-/120645193985?pt= Motors_Car_Truck_Parts_Accessories&hash=item1c17039101
Jeff Bedsor
Reg: 10-2006
Thursday, May 05, 2011 - 07:57 am, by:  Jeff Bedsor (Jeff_bedsor) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looks OK but I would find out what brand turbo they use.
E36 Coupe
Thursday, May 05, 2011 - 08:40 am, by:  Mike Beck (Gold_40gt) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
90 day warranty...
That just screams made in China.
Avoid.
Rowan McMahon
GTT-L
Reg: 07-2010
Thursday, May 05, 2011 - 12:16 pm, by:  Rowan McMahon (Mr_eps) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
YEAH!!! DONT CHANGE YOUR CAR OR TRY NEW THINGS.
EVER.
yeah they're made in china - as is EVEYRTHING these days...
roll the dice on it i reckon - 90 day warranty is fair - and for the price they are.. with our exchange rate, why wouldn't you?
i had a few XS power bits n pieces on my cefiro - such as stainless dump pipe, stainless manifold, stainless 3in exhaust...
it all worked great until the manifold warped and bowed - which, sounds bad i know...
but keep in mind it was a non turbo cefiro that i converted to turbo at age 20 and at the time - there wasn't too much info out there on how to build cars like waht there is now!! :-)
so when i put the manifold bolts on... i did them up in this order:
1, 2, 3, 4, 5, 6
when it should have been:
3, 2, 1, 1, 2, 3
(bolt up from the centre outward to put pressure on the outsides)
it all works GREAT in my opinion so long as you:
A) know what you're doing when putting it on
B) if you DONT know - get someone who DOES. and you TRUST
C) take it like a cheap experiment - if it works - great! you're laughing cos you got a cheap turbo kit... if it goes bang - who cares? you blew 1.5K on a turbo kit that didn't got he way you'd hoped. better to do that than spend $130 a week on a new commodore that depreciates half it's value over 2 years, right?
i know a few guys running china turbo kits - they work..
oh that's my other bit of advice - USE TOYOTA GASKETS!
the only things that let these kits down is their gaskets - they're just... not.. that.. good.
so where possible - get the proper toyota gaskets. if the kit is a GOOD kit then it should all be interchangeable with OEM stuff. do that and the hardware will work great! :-)
eliminate ALL possible errors and you'll be fine...
DDDOOOO ITTTTTT
