  SoarerCentral * Mechanical - TT * General Mechanical * New Radiator (which one) Previous Previous    Next Next
Darren Bak
qld
Reg: 02-2013
Sunday, December 22, 2013 - 01:48 pm, by:  Darren Bak (Dmb169) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Hi, looking ot get a new radiator found a few on ebay, just not sure about fitment, has anyone bought one that will be direct fit off ebay )plastic or alloy)?
found these two, seem identical to me a bit wary of the "sc300" that all of them seem to have.
http://www.ebay.com.au/itm/RADIATOR-TOYOTA-LEXUS-SOARER-TURBO-6CLY-SC300-1993-98-H-DUTY-KOYO-UNIT-/1 90698858958?pt=AU_Car_Parts_Accessories&fits=Model%3ASoarer&hash=item2c6689a9ce
http://www.ebay.com.au/itm/TOYOTA-SOARER-RADIATOR-New-91-00-6-CYL-/230703246985?pt=AU_Car_Parts_Acce ssories&hash=item35b6fc2e89
Steven Soknacki
Ontario
'92 SC400 and '94 GT-T Limited
Reg: 07-2006
Monday, December 23, 2013 - 11:48 am, by:  Steven Soknacki (Sc_coupe) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I can confirm that SC300 fitment is identical to Soarer TT. I replaced my OEM radiator on my '94 Soarer with a Spectra premium CU1305 for a '95 SC300 with no issues.
Darren Bak
qld
Reg: 02-2013
Thursday, January 09, 2014 - 09:59 pm, by:  Darren Bak (Dmb169) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
ended up installing this one instead along with two new hoses
James Buchan
vvt-i turbo
Reg: 10-2008
Thursday, January 09, 2014 - 10:34 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Looks nice and thick. How much did it set you back?
I managed to pick up a second hand Koyorad that's about that size, made out of copper. It's missing some paint but seems to be doing a good job.
Robert Faggian
UZZ31 and VVT-i JZZ30
Reg: 02-2009
Friday, January 10, 2014 - 12:17 am, by:  Robert Faggian (Tanooki_suit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
James - do you know if the VVT-i radiators are different to the TT's? Or to the US SC300's for that matter.
Ali Saeed
RSP JZZ30
Friday, January 10, 2014 - 09:56 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
VVTi radiators are different. The shroud is different
Robert Faggian
Reg: 02-2009
Friday, January 10, 2014 - 12:07 pm, by:  Robert Faggian (Tanooki_suit) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Thanks Ali - it seems that radiators for manual VVT-i's are easy to find, but not so the automatics.
Ali Saeed
RSP JZZ30
Friday, January 10, 2014 - 12:27 pm, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have one for the vvti auto, BUT the radiator top tank is busted.
Best bet for you is to get an auto supra mkiv radiator, modify your shroud / buy supra shroud and use that
James Buchan
vvt-i turbo
Reg: 10-2008
Friday, January 10, 2014 - 11:50 pm, by:  James Buchan (Jrbuch) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Guess I struck lucky with my radiator then.. Had no idea the fan shroud was different, but it bolted in without any fuss.
I'll chuck up some pics when I can
Ali Saeed
RSP JZZ30
Saturday, January 11, 2014 - 12:22 am, by:  Ali Saeed (Ali) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Maybe I am wrong, but I compared a TT shroud to my vvti one and it looked slightly different
