  SoarerCentral * Test Post and Forum Issues * Firefox Browsing Previous Previous    Next Next
Open in new windowArchive through July 25, 2005Geoffrey Williams
Open in new windowArchive through July 26, 2005Peter Nitschke10
Ian Alexander
Tuesday, July 26, 2005 - 03:09 pm, by:  Ian Alexander Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Another point of interest is that if i run the mouse over my own posts it does'nt underline...only as David says when the mouse is run over text(other peoples).
Jeff Wilkins
GT-TL
Tuesday, July 26, 2005 - 03:54 pm, by:  Jeff Wilkins Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Well Ian, Ive noticed mine doesnt do it on some of your posts, this last one it does. Everybody else's it does. Kinda wierd.
Either way it bothers me not in the slightest
Daina Smith
V8 Rules!
Tuesday, July 26, 2005 - 06:31 pm, by:  Daina Smith Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Same here with Firefox, I'm just happy to be using a preferred browser again, the forum being comfortably fast. No probs with MyIE and any drop in speed with the traffic is hardly noticeable.
3.0GT
Wednesday, July 27, 2005 - 10:16 am, by:  Mike Triggs Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I tried forum on IE for the first time and it crashed 3 times, once with the "send error report" window. While it has been crappy lately, it hasn't crashed. Mysterious.
Jason Kingsmill
UZZ31 Soarer V8
Wednesday, July 27, 2005 - 05:36 pm, by:  Jason Kingsmill Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm using Firefox 1.0.3 and I'm also having the underline problem.
It's a real PITA. I thought it must have been the design of the site, but must be a little glitch with Firefox.
Soarer GT Limited (4.0L V8) and is300 (3.0L il6)
Wednesday, July 27, 2005 - 06:27 pm, by:  David Vaughan Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
You are three versions behind and we no longer support that version. Please apply current patches then call again if the problem persists. If it does, we will advise that this is normal behaviour. This is a recorded message.
Monday, August 29, 2005 - 02:03 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Did anyone decide if this is a FF version error or have any other clues?
Monday, August 29, 2005 - 02:32 am, by:  Benny Gammelmark (Oldfield) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Don't know. I had the same problem so I started using IE again. IE works fine for this forum/format. It's a lot quicker than the old.
Monday, August 29, 2005 - 03:49 am, by:  Vinh Bui (Hyudsjk) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
It's not a version error, not from what I know anyway. The latest version (1.0.6) has the same problem described. It's not really a problem, it's only a problem if you want it to be. It doesn't effect my browsing of this forum at all really, but others would probably disagree with me.
Also, Benny's right. This forum loads up a LOT quicker then the older one. Don't have to wait so long to see those topics you really wanna know about anymore :P
Personally, I like Firefox due to the fact that I.E. has wayyy too many security vulnerabilities, and of course, it has the tabbed browsing feature. I hear that the new Internet Explorer (version 7) will also feature tabbed browsing. Damn copycats.
Monday, August 29, 2005 - 07:00 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have switched back to Safari which works without problems. I just tried Firefox 1.0.6 and the text highlighting still happens. That is not a problem so much as the fact that the water-TT moves up and down the page as you scroll, leaving remnants of itself obscuring text on the left. Running your mouse over that text brings it back over the picture again but it is all pretty irritating. The improved Safar (v2.0 vuild 412.2.2)i is as fast as Firefox now and has all its other features.
Monday, August 29, 2005 - 07:11 am, by:  Peter Nitschke (Pen) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
David, a couple of questions then.
1) Should I be bothered about it?
Editing the skin is not a really fun job, small changes can sometimes have ramifications elsewhere. This might be why there is a problem in the first place.
2) If I should worry about it, does anyone have any clues as to what I should be looking for?
3) Does anyone have a good code analyser they can run over a forum pages (as you see here) to get any clues as to why it happens?
3) Or do I just ignore it and hope the issue either doesn't bother people enough, gets fixed in FF, or just goes away somehow?
Monday, August 29, 2005 - 07:34 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I think, like Vinh says, the text highlighting is not a big deal. The watermark problem, given no-one else has reported it, I presume to be Mac-specific in FF and we have an easy alternative in Safari, whereas switching from FF to IE is a loss of function in XP. So, I would see if there are complaints and if not then hope that some other change to the skin equally mysteriously fixes it
Answers to 2 and 3 are no and no unfortunately.
Tuesday, August 30, 2005 - 06:56 am, by:  David Vaughan (Davidv) Quote hilighted text Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
For Mac people, today I got v2.01 (build 412.5) of Safari and it enables the water Soarer at first pass rather than after clicking. Everything else was already working properly.
This is unrelated to FF's problem with dripping bits of the water feature up and down the page.
