  SoarerCentral * Test Post and Forum Issues * Firefox Browsing * Archive through July 26, 2005 Previous Previous    Next Next
UZZ32 ( V8 )
Monday, July 25, 2005 - 05:18 pm, by:  Perry Morgan Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Working fine for me too.
Jeff Wilkins
GT-TL
Monday, July 25, 2005 - 07:11 pm, by:  Jeff Wilkins Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Doing the underline thing for me as well. Firefox V 1.0.4 running under XP SP2.
Monday, July 25, 2005 - 07:33 pm, by:  Don Bagnall Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I'm running alternately in IE6 AND Firefox.
No problems with either.
Running SP2 with broadband.
Geoffrey Williams
UZZ31 V8 Soarer and LS400 Lexus V8
Monday, July 25, 2005 - 07:46 pm, by:  Geoffrey Williams Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I've got no problems with either IE6 or FF V 1.0.4. I'm running XP Home SP2. Cable internet.
Soarer GT Limited (4.0L V8) and is300 (3.0L il6)
Monday, July 25, 2005 - 08:01 pm, by:  David Vaughan Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
I have no problems with Firefox or Safari. Have you looked at the "Underline links" option in Preferences, or whatever it is called in your OS?
3.0GT
Monday, July 25, 2005 - 10:54 pm, by:  Mike Triggs Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Tried Netscape at work and got the underlining thing occasionally, too. The forum worked fine though.
Monday, July 25, 2005 - 11:33 pm, by:  Peter Nitschke Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Weird, so it isn't consistant for all Firefox users then?
Tuesday, July 26, 2005 - 07:05 am, by:  David Vaughan Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
A few clarifications:
I am running the browsers on OS X 10.4.2
Firefox underlines text as if it were a link only when I mouse over the text, as it does for links. Firefox uses the Mozilla engine so you should see similar behaviour in some other non-IE browsers. It may be that some see it as a problem and others do not. That is, behaviour is the same but reports are different.
No such behaviour in Safari, which I think uses the Gecko engine.
I have discovered a Firefox bug where the Java applet which supplies the Soarer visual at top left can leave bits of itself scattered up and down the page on the left side if you scroll by clicking the arrows. Safaris does not have that problem.
Normally I find Firefox a very good browser. Despite these glitches, it still beats IE's lack of tabbed browsing, but now that Safari goes faster I am using the latter anyway.
Tuesday, July 26, 2005 - 07:10 am, by:  David Vaughan Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
Firefox 1.06 which is Mozilla 5.0.
Safari is v2.0 build 412.2
Tuesday, July 26, 2005 - 07:20 am, by:  Peter Nitschke Edit Post Delete Post Print Post   View Post/Check IP (Moderator/Admin Only) Move Post (Moderator/Admin Only)
That is useful feedback (I think). I use Crazy Browser with IE to get tabbed browsing, works a treat, also I have it set to open new windows in background which is excellent for forum work.
